Old 05-02-2019, 01:20 AM
Dessertrunner's Avatar
SVX with ITB
AS the title says I have the car running with ITB just need to head to the dyno for tuning then head to the race track.
https://www.youtube.com/watch?v=FXy0IyAwy8Q
Old 05-02-2019, 06:20 AM
RallyBob's Avatar
RallyBob RallyBob is offline
Registered fabricator
Re: SVX with ITB
Nice throttle response! Curious about the power changes with this setup.
What size throttle plates are you running?
Bob Légère
EG33 Impreza tweaks
Old 05-02-2019, 10:48 AM
SoCoNoHa's Avatar
SoCoNoHa SoCoNoHa is offline
H6 Fanatic
Re: SVX with ITB
Please please please tell me the stacks will protrude from the hood!? That would look so badass!
Great job, are you running aftermarket engine management? I don't see a MAF...
Can't wait to see video of you tearing up the track!
1992 SVX LS-L : King of the Stable
LGT 5MT, ABS Delete, Short Ram Intake, Custom Exhaust, Drilled/Slotted Rotors
1993 Legacy sedan : winter beater, supposedly.
1994 Legacy wagon : future drift car?
1995 Impreza coupe : EZ30++, daily racecar.
1997 Legacy GT : date night rocket?
2003 WRX : future winter beater
Old 05-03-2019, 02:53 AM
Re: SVX with ITB
Hi Bob,
Running 45 mm have even considered going down to 42 mm. Right now I expect peak torque around 7,500 rpm.
Old 05-03-2019, 02:55 AM
Re: SVX with ITB
I am running a Link ECU and the maps are based On TPS & rpm.
The stacks will be inside a air filter box so not visible.
Old 05-03-2019, 11:01 AM
svxnavyvet svxnavyvet is offline
Re: SVX with ITB
Did you go with larger valves +1mm?
Old 05-03-2019, 01:36 PM
Re: SVX with ITB
Standard diameter valve, here is the spec
Okay its spec's,
Standard bearings,
High grade rods from Spool,
Pistons are 11.5 ; 1 made by CP in the USA,
Valves longer by Supertech,
Solid buckets,
Matt's high lift cams,
IVO 6 BTDC IVC 40 ABDC
EVO 50 BBDC EVC 9 ATDC
ITB 45 mm diameter, head average area 46 mm. Distance from bell to intake valve is 400 mm. Expect max torque at 8,000 rpm.
Volume in ITB including head is 0.64 litres and the cylinder capacity is 0.55 litre
Injectors are 550 cc ( which maybe too small) we have 860 cc and 1,000 cc if needed.
Have refitted Matts extractor pipes they are 3 into 1. 42 mm ID from engine then join 3 into 1 pipe which is 55 mm ID which is 900 mm from the manifold. Were the pipes join together there is a single pipes per side and they are 60 mm ID all the way to the back.
Peak piston speed at 9,000 rpm will be 22.5 m/sec, which is about the same as most 4 AGE's at 8,000 rpm. If we run to 11,000 we will be more inline with most race engines at 27.5 m/sec.
Engine tune table is TPS and rpm,
Brakes get vacuum from a electric vacuum pump.
Old 05-04-2019, 08:29 AM
Huskymaniac's Avatar
Uses the ignore feature
Re: SVX with ITB
Old school. Took this pic at the Ferrari Museum in Maranello.
Tony
Old 05-04-2019, 09:28 AM
wdb wdb is offline
dances with roads
Re: SVX with ITB
Sounds downright wicked!
1995 Caterham 7 Twincam
2007 BMW 328i Cabriolet
2012 Tacoma 4wd v6 Access Cab
Old 05-04-2019, 12:00 PM
Re: SVX with ITB
Thanks for the update on the engine spec's
