Old 10-29-2018, 02:31 PM
bumpsteer's Avatar
bumpsteer bumpsteer is offline
Recovering EG33 Swap Artist
AVCS on EG33?
Has anyone looked at a DOHC EJ AVCS cam-phaser and an EG33 cam pulley side-by-side? I am curious if it would bolt on, or if it's close enough that you could sleeve the camshaft with a taller key, if the pulleys are the same diameter, or if it's completely just different offset and in no way adaptable.
I understand that EG33's drive both cams off one pulley, but VCT seems to be useful in some SOHC applications, so I'd imagine there would be some benefits if you have a standalone capable of pulling it off. EG33 is non-interference so you are less limited in your cam-phasing.
Just looking into it as I plan on RusEFI'ing my EG33 eventually and am looking to have a little fun with it.
Cheers,
Ryan
-1996 Brilliant Red LSi *slow*
-2007 Mustang V6 *slow*
-2002 Audi Allroad 2.7t 6spd *slow*
Ask me about a certain midengine Honda Insight
Old 10-31-2018, 04:01 PM
Re: AVCS on EG33?
Cheers,
Ryan
Interesting Ryan, but how would you get the activating oil pressure through the cam to drive it?
Old 11-04-2018, 07:52 PM
bumpsteer's Avatar
Re: AVCS on EG33?
Welp, there's the one thing I didn't think about. I imagine you could have the cams bored out on a lathe or gun-drilled, but things get hairy getting the oil into the cam then. I'll think on this more!
Edit: It seems that the oil doesn't actually run through the cam, so you'd "just" need to figure out a creative way to route the lines between the cam pulley and the head itself (can't go through the head as the secondary cam gears are in the way) and mount the solenoid somewhere.
https://www.google.com/amp/s/www.iwi...05-WRX%3F_amp_
I really need to get my hands on some of these components.
Old 11-04-2018, 11:34 PM
Re: AVCS on EG33?
Well yes it does as the ACVS rotates.
If you look at the diagram that you linked to.
The system is, oil pressure is switched by the solenoid to a feed that goes into the head casting to feed the front cam bearing, the cam has a hole in it, that connects by a drilling through to the front of the cam, to the ACVS. Bit of machining on the cam shaft, and some oil passages drilled in the head, not insurmountable.
Tags
avcs, eg33, ej20, ej25
