Go Back   The Subaru SVX World Network > FAQs, How To's, & Vendors > Vendors, Service, & Parts
Old 09-15-2018, 03:35 PM
JudyS JudyS is offline
Smile needed rear strut mounts & struts for a 1994 SVX
Help! I cannot locate rear strut mounts for my 1994 SVX, Can anyone offer some help!
Old 09-15-2018, 03:46 PM
92 SVX 92 SVX is offline
Re: needed rear strut mounts & struts for a 1994 SVX
At this point I believe its cheaper and easier to buy coil overs for the car, they should ride as well as stock with better performance and they can be had for cheaper (assuming you can find them) then oem struts and top mounts.
Old 02-17-2019, 01:27 AM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
check this link - they do come up from time to time ....
https://www.jauce.com/search/subaru+svx
Old 10-03-2020, 03:41 PM
SURTEESS's Avatar
there is a 4WS SVX being parted out - it has OEM shocks and the top hats look clean each shock is approx US$45each https://www.jauce.com/user/upjpn17?&...x&n=100&page=1
