Reverse slipping badly
Hi, I bought a 1991 SVX a year ago and noticed it slipped a bit when reversing (I.e. engine revs rose but speed didn’t) but it wasn’t too bad. I put it straight into dry storage for a year while I sold some other cars, then last week I took it of storage to find that reverse is a good as useless, engine revs but car doesn’t reverse unless on completely flat ground, slightest incline and no movement at all.
Does this sound terminal for the transmission or should I try oil and filter change first ? All forward gears seem fine... all suggestions welcomed.. |
Re: Reverse slipping badly
Did you check the level of the transmission fluid? It could be very low. I know it sounds silly but start with the basics.
1997 Bordeaux Pearl, 2006 Alfa Romeo Brera 3.2 6MT, 2010 Mercedes Benz GLK350, 2018 BMW 640i GT Xdrive, 2012 Moto Guzzi Norge GT 8V, |
Thanks, sorry should have said that but yes indeed that was the first thing I checked... looked fine in terms of colour and quantity...
loss of reverse is a signal to the start of a major failure of a stage 1 4eat ,reverse is manually engaged and when failure from oil starvation starts it takes out the reverse clutch
if you have it rebuilt the best case to use is a 98 legacy or outback 4eat because they fixed the oil problem before they ended use in 99 |
