Old 11-01-2017, 01:23 AM
Sleeve Lock Regulator Replacement with PHOTOS
http://www.subaru-svx.net/forum/atta...1&d=1509520964
Old 11-01-2017, 07:10 AM
SoCoNoHa's Avatar
SoCoNoHa SoCoNoHa is offline
H6 Fanatic
Re: Sleeve Lock Regulator Replacement with PHOTOS
Well, SOMEONE gets up early...
Thanks Svxcess, now that I know where It goes, I'll check the ones in my doors. One of those was in the glovebox when I bought my SVX, but my windows seem to work fine so I never looked into it.
1992 SVX LS-L : King of the Stable
LGT 5MT, ABS Delete, Short Ram Intake, Custom Exhaust, Drilled/Slotted Rotors
1993 Legacy sedan : winter beater, supposedly.
1994 Legacy wagon : future drift car?
1995 Impreza coupe : EZ30++, daily racecar.
1997 Legacy GT : date night rocket?
2003 WRX : future winter beater
Old 11-01-2017, 12:39 PM
gwynethh's Avatar
gwynethh gwynethh is offline
Thank you very much. It is only a matter of time before most of us will nee d this info.
"Peace is the flower of justice."
Old 11-02-2017, 04:48 AM
This part shows up as no longer available (NLA) on most sites. Its a perfect candidate for 3D printing - small and made out of plastic.
As soon as my baby gets a little older, I want to dive into creating parts for the SVX on a printer and making them available for download for free. Hopefully by then there will be more viable and cheaper options for 3D scanners.
Old 11-03-2017, 01:05 AM
svxnavyvet svxnavyvet is offline
I have a 3d printer and a kid that can auto cad anything will look into this.
Old 11-04-2017, 11:54 AM
That would be fantastic. As long as the material is a strong as the nylon original part to handle whatever stresses there are.
This is a part that could take many SVX's off the road if it could not be replaced. Every sale that needed a safety inspection to be registered would fail if the primary windows did not operate.
Old 03-24-2019, 03:39 PM
Exclamation Re: Sleeve Lock Regulator Replacement SOURCE
UPDATE
Just to let you know, the sleeve lock regulator used on the rear windows is the identical one to the front. Though used, the yprobably are stronger, since the rear windows get far less usage over time and the strain on the regulator is far less since the window is smaller and lighter in weight. As long as you're going to a pick n' pull, might check this location for spares.
File Type: jpg 54727421_270380177221320_7292289323926290432_n.jpg (23.6 KB, 2891 views)
