Old 10-27-2017, 11:21 AM
Sideshot Sideshot is offline
Can/Has it been done?
I have had this idea in my head for a way to make the SVX into more a performance machine. I know everyone loves the 3.3 but I was thinking of a complete wrx sti swap, driveline and all. just an idea but do y'all think it can even be done?
Old 10-27-2017, 12:03 PM
SoCoNoHa's Avatar
SoCoNoHa SoCoNoHa is offline
H6 Fanatic
Re: Can/Has it been done?
I haven't read of it being done, but I can't see why it wouldn't be possible. Mechanically everything should bolt up, with a 6 speed you can use the stock SVX driveshaft and (I believe) rear differential. If the EG33 will drop into any EJ series chassis, which it seems to, then the EJ2x7 should drop right into the SVX. Plus you'll have extra space in front of the engine.
Problems I foresee consist of intercooler/charge pipe location and possibly needing to find a shorter radiator. Perhaps you could get away with using the SVXs rad.
Then of course is the wiring, typically the most convoluted party of any Subaru swap. I'd grab an OBD1 SVX, but that's because I have to pass an OBD2 check with '96 and newer vehicles here in NH.
At that point you'll have all the power you can afford, and there seems to be solutions for upgrading to STI suspension.
It's still a heavy car though, a few hundred lbs more than the STI, so it won't be QUITE as fast at similar power levels, but still much faster than stock. Please keep us updated if you go that route. If you're near southern NH I'd be happy to help, sounds like a fun adventure.
1992 SVX LS-L : King of the Stable
LGT 5MT, ABS Delete, Short Ram Intake, Custom Exhaust, Drilled/Slotted Rotors
1993 Legacy sedan : winter beater, supposedly.
1994 Legacy wagon : future drift car?
1995 Impreza coupe : EZ30++, daily racecar.
1997 Legacy GT : date night rocket?
2003 WRX : future winter beater
Old 10-27-2017, 05:51 PM
92 SVX 92 SVX is offline
physically it will all bolt up, wiring would be doable, just backwards of what most do, H6 into a stock H4 car, has anyone actually done it.. yes but the project stalled out on wiring and then was parted out and sold I believe
Old 10-27-2017, 07:32 PM
socal1200r's Avatar
socal1200r socal1200r is offline
Just about anything can be done if you throw enough money at it...
I'd rather see someone power up a stock EG33, and of course do an MT swap as well, all in the same car...
For example, I'd like to see someone install one of these SCs onto an EG33:
http://www.wynjammer.com/GM_S10_4_3_V6.html
There seems to be a few SVX folks on here that appear to have the skills to do it. I would think the combo of this SC and an MT on an SVX would really make it entertaining to drive!
1997 Subaru SVX LSi
Honda Accord wheels 17x7.5, 235/45s, 5mm rear wheel spacers; "3.3" and "AWD" badges on front fenders; AMR radiator/fans; lowering springs, s/s brake lines, drilled rotors; Stebro exhaust with quad tips, mid-muffler removed; tinted windows.
Old 10-30-2017, 08:38 AM
A LOT of that extra weight is the EG33 and the 4EAT, I bet with a STi motor and transmission, it would weigh in right about the same as the STI
Old 10-31-2017, 06:00 AM
SoCoNoHa's Avatar
H6 Fanatic
I believe the 6 speeds are deceptively heavy, as heavy as the 4eat's anyway. That plus intercooler/piping and a turbo had me figuring on minimal weight savings from a drivetrain swap. Just speculation of course.
https://forums.nasioc.com/forums/sho....php?t=1571494
Edit: from what I can tell the eg weighs around 400 pounds, and the ej257, with its aluminum block, weighs about 200 pounds. That's without the turbo stuff, but it's still a substantial weight savings on the front end.
Old 10-31-2017, 10:06 AM
Talking on this is about like we were thinking back in the late 90's: Why not put a 91-94 EJ22T block in it, and boost it to 30psi on stock internals with tmic...? wasn't done then, and probably same now.
Just saying.
1985 Brat GL 138k
91 CRX Si 40k
91 CRX Si 155k
97 SVX Lsi 70k
2003 s2000
91 RT4WD 166K
