Old 05-16-2017, 08:17 AM
zavikan zavikan is offline
trouble with new SVX remote
I just purchased a NOS oem svx keyless entry remote....
The original battery inside was a bit corroded, but not to bad. I replaced it.
Tried to do the programming but it has not worked...
I can get the car into programming mode easily, but when I press the remote 4 times it doesn't seem to have any affect on the car.
'92 Liquid Silver SVX - Drilled&Slotted Rotors/Canadian OEM Seat Warmers/JDM Folding Mirrors/JDM Clear Corners/Euro Glass Headlights/Euro Headlight Level Adjustment/Euro Shifter Assembly/ECUTune Chip V.1/GARAGE QUEEN!
Old 05-16-2017, 09:17 AM
Re: trouble with new SVX remote
Once in programming mode, the parking lights should flash with each press of the button. They illuminate when the button is pressed and goes out when the button is released.
A total of four times
Old 05-23-2017, 01:52 PM
fasteract7's Avatar
fasteract7 fasteract7 is offline
A total of four times...?...for 2 remotes ? Instructions suggest press 2 times when in programming mode per remote, right ?
THX
1992 Dark Teal LSL, 4.44 swap, B&M trans cooler, AFPR, RX8 rims, 235/40-18 tires, SS brake lines, Hawk HPS pads, Strongflex poly ft/rr swaybar bushings, starter solenoid mod.
Old 07-19-2017, 06:35 PM
Austin Austin is offline
That's how I read that too. Not totally sure though. I need to try this.
I just got this SVX a few months ago and it came with a (very worn) remote. I put a new A23 battery in it but got nothing. Didn't know about this programming bit though.
The car also came with a couple of generic remotes too - I wonder if it'll work on those?
Austin
__________
'97 LSi Ebony - daily driver - mostly just needs body work [couple o' rust holes, door dings, and peeling clear (of course)]
'96 LSi, Laguna Blue (retired - soon going to a new home)
'89 XT6 5 speed (Gone but not forgotten)
