Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Supercharged Projects
Old 05-03-2017, 04:18 PM
socal1200r's Avatar
socal1200r socal1200r is offline
VW G60 supercharger
Has anyone tinkered around with using a VW Corrado G60 supercharger on an SVX? It looks like it's a pretty small unit, which should help with mounting, running a drive belt, and routing the incoming and outgoing air, especially if you don't run an intercooler...
Anyone?
1997 Subaru SVX LSi
Honda Accord wheels 17x7.5, 235/45s, 5mm rear wheel spacers; "3.3" and "AWD" badges on front fenders; AMR radiator/fans; lowering springs, s/s brake lines, drilled rotors; Stebro exhaust with quad tips, mid-muffler removed; tinted windows.
Old 05-03-2018, 06:37 AM
bumpsteer's Avatar
bumpsteer bumpsteer is offline
Recovering EG33 Swap Artist
Re: VW G60 supercharger
Anyone?
I can't imagine the g-lader flows enough for the EG33. With the stock pulleys it didn't make more than 200hp..
Finding a used aftermarket centrifugal supercharger would likely be less expensive, last longer, and match the EG33 better with similar or improved packaging.
-1996 Brilliant Red LSi *slow*
-2007 Mustang V6 *slow*
-2002 Audi Allroad 2.7t 6spd *slow*
Ask me about a certain midengine Honda Insight
Old 05-03-2018, 04:33 PM
Stevebsy's Avatar
Stevebsy Stevebsy is offline
Administrator
Someone should check out the SC from the Audi 3.0T engine.
IT has built air/water intercoolers and seems about the right size/shape.
'20 Honda Ridgeline
http://www.x35design.com
