Old 11-20-2016, 08:33 AM
DallasSVX92's Avatar
DallasSVX92 DallasSVX92 is offline
Svx not starting
My 92 SVX has been sitting for over a year now, and I've still had no luck getting it to start. I will admit I haven't put in the most effort but work has been taking its toll on me. Pretty much the svx would start right up every time, but I went around 2 months without starting it and now it just turns over. Im not getting spark or fuel, even after changing the fuel pump. I also noticed that the radio and interior lights don't have power to them, not sure if that's related or not. Any help would be appreciated.
Old 11-20-2016, 08:38 AM
SVXNATION's Avatar
SVXNATION SVXNATION is offline
SVXNATION
Re: Svx not starting
step one check fusable link in the forward fuse box
http://i18.photobucket.com/albums/b1...usiblelink.jpg
Come Join The Nation
We are a combination of both the Network the Forums and a plethora of new bloods! We have close to 6000 members on all forms of social media worldwide. What's all the fuss about? We're just the next logical step in a social media-driven World! As one of the community's longest-running members explained: If the the traditional forums are the library... SVXNATION would most certainly be the popular corner coffee shop
www.svxnation.com
Old 11-27-2016, 03:01 AM
kwren's Avatar
kwren kwren is offline
it will crank with a bad (open) fuseable link?
Sorry, 2 am here and haven't pulled up the wiring diagram. Just got on and saw the question.
Old 11-27-2016, 08:24 AM
well my Fuesable link wasnt blown, but the contact points were very corroded so I replaced it anyways with a brand new one. My battery is currently dead and jumping it dosnt give enough power. Ill be getting a new battery tomorrow and we'll see what happens.
Old 11-27-2016, 03:45 PM
Got a new battery, still just turns over. No spark or fuel. I realized the svx stopped running around the time I removed the wire that went from battery, through the fire wall and to my amp. I wasnt thinking and I just pulled that wire out of the fire wall staright from under the hood. Could I have unplugged somthing by doing so?
Old 11-28-2016, 03:04 PM
SVXNATION's Avatar
SVXNATION
Very likely do you still get your check engine light with the key in standby? Just want to verify your ecu is intact
www.svxnation.com
Old 11-28-2016, 06:00 PM
yeah I get the CEL, I know how to check it using the two wires under the dash but nothing happens when I do this
Old 11-29-2016, 07:29 AM
Stevebsy's Avatar
Stevebsy Stevebsy is offline
Administrator
It seems that it's an electrical problem.
I'd start with rechecking all the fuses, links, etc. Both under the hood and in the cabin fusebox.
If those look good, I'd find the wiring diagram and check for power at the ECM next, as that drives fuel and spark delivery.
If I remember, there is a whole section in the FSM about how to trace such a problem, where it just is a giant flow chart of checking stuff and seeing what happens.
Try that and see what happens.
'20 Honda Ridgeline
http://www.x35design.com
Old 11-29-2016, 04:30 PM
I'll have to give that a try this weekend, this poor svx has been sitting for far too long. On another note,I painted the SVX lettering on my battery bar, It's beautiful.
Old 11-29-2016, 08:49 PM
Svx95's Avatar
Svx95 Svx95 is offline
eg33svx95
Check your MAF, if you have a spare swap it out.
Also, you mentioned replacing the fuel pump. Make sure the plug at the tank has all wires intact. Sometimes the wires break inside the shielding when removing the plug, if not done correctly. i.e., by pulling on the wires instead of only pulling on the plug. (Don't ask me how I know)
Sam
Brilliant Red 95 SVX L AWD 149K miles - #904/1801, 08 STI 6MT with DCCD & VSS, ACT SB10 HDSS, 6MT bushings, DW200 Fuel pump, 17x7.5 VX-SCYTHE Wheels, 17x8 BBS STI Wheels,PERRIN CRANK PULLEY, 911 Turbo oil filter,$15/15min MOD & $20/20min Mod, Brontrager WORKS 22mm RSB w/ QS component endlinks, SS Brake Lines, DDM TUNING 6000K HID LOWS, Hella Optilux Extreme Yellow Fog Lights,Window scratcher fix, JDM Clear Corners
