Old 09-18-2015, 01:15 PM
rj7630 rj7630 is offline
Manual install question
I am getting ready to install a 2004 WRX 5 speed. In reading the instructions I downloaded one step says install modified/WRX brake booster. I do not have the WRX booster, so what needs to be done to the SVX booster?
Old 09-20-2015, 11:40 AM
Gamesy's Avatar
Gamesy Gamesy is offline
Re: Manual install question
i used the stock booster
but i also moved the pedal assembly about 1" away from the firewall
Old 10-02-2015, 04:00 PM
Still not sure what needs to modified on stock booster. Is the shaft too long and need to shortened?
Old 10-05-2015, 07:38 AM
EdWindows's Avatar
EdWindows EdWindows is offline
5spd + coilovers = win :D
You do not need modify the booster if you are modifying the stock brake pedal assembly to include the clutch mechanism. This is the proper way to do it given that the pedals will sit at the right height.
You only modify the booster if you choose to bolt in whatever donor pedalset you have, but then the clutch and brake pedal will be way sunken in compared to the throttle.
1992 Dark Teal LS-L w/ 165k+ miles (traded )
Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs
2001 Black Toyota Sequoia (hauler/daily)
1992 Blue Toyota Cressida (drift car)
1992 Red Toyota MR2 (weekend/track day car)
