Old 09-11-2015, 09:49 AM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
Need Rear Brake, Turn Signal Wiring Harness
It is a plug with wires to sockets serving the rear fender brake and turn signal. Part # 8431PA000 is not longer available from Subaru.
Thanks.
Gene and Ben
Old 09-11-2015, 10:49 AM
Re: Need Rear Brake, Turn Signal Wiring Harness
You're missing one digit from the first part of the part#. I most likely have what you need if I know exactly what it is.
Is it easy to get to?
If it's 84931PA000 it seems to be available for $4.32.
https://subaruonlineparts.com/sop-parts/#parts
Old 09-12-2015, 08:06 AM
bwb3's Avatar
Thank you for the lead Blacky. Subaruparts.com listed it as not available.
The part is easy to get to. Just remove the trunk access panel, unplug the bulb sockets, unplug the harness plug.
Gene
Gene and Ben
