Old 07-13-2015, 06:42 AM
johnnyride johnnyride is offline
SVX and EZPass
Hi all,
Just wondering if anyone else has this problem. I cannot get EZPass to work in my 92 SVX. I have tried two of them. They work in other cars, but not the SVX. Anyone else have that problem? I have tried two of them in the car. Could it be interference with the security system? I'm pretty sure the car isn't made of some allow that blocks the signal!
Thanks, john
Old 07-13-2015, 06:56 AM
processengr's Avatar
Re: SVX and EZPass
Hi,
Do you have it mounted behind the windshield? Do you have the bronze tint?
Cheers! Gordon
1992 Ebony 251k 444 SOLD
1999 Silver SLK230 134k SOLD
1997 Green Outback 137k SOLD
2013 Honda Accord I4 SOLD
2015 Subaru Crosstrek 30k
2018 Tesla M3 30k
Old 07-13-2015, 07:24 AM
Re: SVX and EZPass
Originally Posted by processengr View Post
Hi,
I have it mounted just behind the rear view mirror. And bronze tint? Do you mean up at the top?
Do you think I should mount it closer to the bottom?
Thanks,
john
Old 07-13-2015, 07:33 AM
shotgunslade's Avatar
Re: SVX and EZPass
Doesn't matter if it is a bronze tint or not. EZPass will not work behind the windshield of an SVX, something about a metallic coating even on the clear windshield. This has been the case for all 3 of my SVX's, none of which had tinted windshields. I have always used the exterior EZPass transducer that is mounted on the top of my front license plate mount.
Old 07-13-2015, 07:39 AM
Re: SVX and EZPass
Great info. Thank you so much!
john
Old 07-13-2015, 10:32 AM
Re: SVX and EZPass
Yes the windshield blocks it, but the bumper mount is quite ugly. I put mine in the back window between the speakers and it seemed to work well back there. However I no longer live in a area where I am on the turnpike a lot with the SVX so, I generally keep it in the armrest and hold it out the window.
Old 07-13-2015, 01:26 PM
Re: SVX and EZPass
titanium coated glass is standard.
1985 Brat GL 138k
91 CRX Si 40k
91 CRX Si 155k
97 SVX Lsi 70k
2003 s2000
91 RT4WD 166K
Old 07-13-2015, 08:39 PM
Re: SVX and EZPass
... or the sunroof.
Old 07-14-2015, 08:40 AM
SVX_MY_BABY's Avatar
Re: SVX and EZPass
Originally Posted by Hocrest View Post
... or the sunroof.
That's what I do Just hold the pass up as I drive through. Locally the commission which gives out the transducers has a list that they check of vehicles which block the signal. Surprised your jurisdiction doesn't. The SVX is not unique.
There was a thread about this quite awhile back. I recall that somebody somehow mounted the pass inside their waterfall grill.
Peter
