Old 02-02-2015, 08:59 PM
BRADY's Avatar
BRADY BRADY is offline
SVX Addict
Send a message via MSN to BRADY Send a message via Skype™ to BRADY
Unhappy Help!
Hi all. My baby is misfiring and seems to be running on half the cylinders.
Just started today after heavy rain.
What usually causes this?
I am mechanically retarded.
1992 SVX Mica Red/Black (Ruby Pearl) (ADM)- 290,000 kms. With Koni adjustable front shocks, THRICE o/hauled 4EAT with transmission cooler and now the 'QUICK CHANGE' unit, custom PWR aluminium radiator, replacement water pump, fuel pump, crank pulley, Pioneer 6 x 9 rear and 6 inch front speakers, Sony Head unit, rattles from the front end and steering, front DBA slotted rotors. Blown heater core, ruined CV joints, new car park damage. FOR SALE... www.thebeatleboys.com
Old 02-03-2015, 10:01 AM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Re: Help!
Could be the "limp home mode"
mine did this a few years ago - due to error code 12.
This was caused by temperature sensor - only cost $30 to fix
Old 02-03-2015, 11:04 PM
Tapani Tapani is offline
Re: Help!
You may want to check the QC connections... mine scared me *hitless when the torque control was activated during normal driving..... just a bad connection.
/T
Tags
misfire, sick
