Old 01-21-2015, 01:51 PM
Cruise were did it go
Cruise was working the last times I used it. Today nothing. The dash indicator light comes on. Will not engage. I checked the vac hose on the controller on firewall. Looks ok. Thinking clutch switch or brake switch.. Any other suggestions?
Old 01-21-2015, 03:16 PM
gwynethh's Avatar
gwynethh gwynethh is offline
Re: Cruise were did it go
If it is the brake switch would the brake lights be on all the time the car is running?
"Peace is the flower of justice."
Old 01-21-2015, 04:23 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Check the horn fuse.
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
Old 01-23-2015, 10:53 AM
wdb wdb is offline
dances with roads
Horn fuse? Tell me that's a joke...
1995 Caterham 7 Twincam
2007 BMW 328i Cabriolet
2012 Tacoma 4wd v6 Access Cab
Old 01-23-2015, 11:58 AM
How about I just try blowing the horn. Tell the truth I have not blown the horn in months... Funnier thing have happened. I lost my clock, dome light and alarm one fuse.
Old 01-23-2015, 06:22 PM
dannmarr's Avatar
I work for my SVX
Part of it shares the same circuit. Try fuses 12 and 18
Subaru SVX for fun
Old 01-26-2015, 05:14 AM
Also check to make sure the vacuum hose hasn't popped off the Diaphragm for the Cruise Unit under the hood..
Old 01-26-2015, 01:24 PM
Andrew P.'s Avatar
Andrew P. Andrew P. is offline
The Ebony ones are faster.
When you push the cruise button, can you hear a "click" coming from the passenger side of the dash?
If not, you could have a bad c/c relay.
There are 2 of them and they can be a pain to get to. Located behind the glove box.
Just in case, here are the part #s: 82501AA150 and 82501AA160.
Hope it might help.
92' Ebony. Magnaflow exhaust, tinted windows, STI wheels, 97' grille, Bontrager Works SB, ECUtune transaxle and TCU.
77' IHC Scout SSII
Old 01-29-2015, 09:26 AM
dannmarr's Avatar
I work for my SVX
any updates if this was solved? Would be beneficial for all of us
Subaru SVX for fun
Old 04-26-2015, 01:37 PM
Yesterday at the Reading meet we checked under the hood. Huck said bang on this black box. Just under the battery and the radiator overflow bottle. Now my cruise always did work and suddenly stopped. If yours never worked this May not solve it , mine is back to normal after the banging. THANKS HUCKSTER
Old 04-27-2015, 08:24 AM
You're very welcome
