Old 01-06-2015, 09:24 PM
andreoz andreoz is offline
Send a message via Skype™ to andreoz
Tacho strange behaviour
Some 12 months ago my tacho started registering to max just over 2K as if its total scale of movement got limited to just over 2K. I didn't feel like ripping out the instrument cluster from the dash to check things out. Some 3 months ago, for no reason at all I noticed that it was again working correctly. Well, now all of a sudden it stopped working completely!!
Anyone with any experiences with their tachos? Sounds like it may have been a loose connection which came good and now is broken completely.
Any advice will be welcome.
Old 01-07-2015, 06:03 AM
LarryIII LarryIII is offline
Re: Tacho strange behaviour
In all my years with SVXes never heard of a tach problem. Check your rpm sending unit.
Larry III & The Beautiful Naviguesser
'19 Tungsten Pearl Outback 3.6R Ltd...."AISHA"
'08 Harvest Gold Outback 3.0L. L. L. Bean...."AIJOU"
'07 Gray Diamond Pearl Outback XT Ltd..."AH SO"
'05 White Pearl & Silver BAJA Turbo..."AH HA"
'97 Bordeaux Pearl SVX LSi..."SUBYDOO"
'94 White Pearl SVX LSi..."PEARLY"
'92 White Pearl SVX LSL w/touring pkg..."SVXY"
'92 Teal SVX LSL w/touring pkg..."ALCYONE"
'96 Polo Green LSi ... "MIDORI"
'00 Black Dodge VIPER RT-10... "VINNIE"
Engineers do it with precision.
English teachers are novel lovers.
Home: larrysingeriii@comcast.net
SVX FEVER, CATCH IT AT A MEET NEAR YOU !!
Old 01-07-2015, 08:54 AM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
I can't help in diagnosing the problem but, did experience the same. The tachometer struggled to reach 2000 rpm and stopped there. At the time, I found a replacement gauge cluster and swapped it out. The replacement tach still works fine, 3 years later. On the old gauge cluster, I could not visually see and breaks in the wire connections or circuit board.
Gene and Ben
Old 01-07-2015, 11:19 AM
Are you sure the needle is not rubbing the face? The needle is very sensitive to pressure....
