Old 10-19-2014, 06:43 PM
WYOSVX's Avatar
WYOSVX WYOSVX is offline
AMR Coilover install questions
I've finally put the SVX in my shop to install the AMRs. I've admired them sitting on the shelf long enough. I've skimmed the posts and haven't found details that might answer my questions. My skill level is such that I've never worked on a strut or coilover suspension but I'm reasonably competent- it doesn't look to be all that difficult- but, I know the devil's in the details. Since I have the rear deck off, I'm also changing out speakers and will look at my window brushes in the back, then, later, the front brushes when I change out the door speakers. First, though, the suspension.
So, I pulled a rear strut and stood the coilover next to it and adjusted it to be the same length which, of course, did not give the same ride height. So, I've been messing with it a bit, adjusting the lower sleeve to get the same ride height. The problem I run into is that I really have to jerk the whole brake disc and strut knuckle pretty hard and it's tough to line up the coilover with the holes in the knuckle. Maybe that's okay but I want to check with anyone else who has installed these. I'd rather not create a problem. Right now, the coilover is much shorter than the strut and I think I still need to shorten it. The distance between wheel well lip and tire on the strut side is about 1/4". On the coilover side, it's over an inch. I prefer 1/4" but I worry about how much I'm forcing the coilover to line up with the knuckle. Should I not worry?
Regarding adjustment: I've only adjusted the lower tube and collar that the knuckle attaches to. I'm assuming that I shouldn't mess with the collar at the base of the spring. Is that true?
And, when I put the adjuster screws on top for adjusting the ride firmness, can I make the adjustment, then pull the screw so the hood isn't dented by it? Will it hold the setting?
Any advice? Am I messing with something I shouldn't mess with?
One complaint so far: the brake line clips. One is set about 45 degrees off and the screws don't fit; I've got to buy the right size screws. Small details, but I think I paid for more attention to detail.
Thanks!
Old 10-26-2014, 11:47 AM
WYOSVX's Avatar
Re: AMR Coilover install questions
Having no advice to go with, I went ahead and did the coilover swap. It was fairly easy and the screws actually fit once I cleaned out the powder coat from the threads. There are some details of the swap I'm a little unsure of, but I'll have my mechanic check my work. What I don't like is how loosely the coilovers fit in their respective knuckles- just like the struts, allowed for a small amount of variation in wheel camber. Not knowing any better, I expected it to be more precise.
If anyone with coilover experience has any advice, warnings, something I should look out for, let me know.
The ride height is a little low but I think it looks cool so I'll leave it for a few days.
Ride comfort is better than expected. I thought it would be like a logging truck but, even on the gravel roads, it firm but not abrupt. Don't know how else to explain it. I wouldn't know how to compare it to anything else on a race track in any kind of slalom but I expect I'll be able to accelerate more smoothly now because when I shift gears now, there's no front/rear rock when I push in the clutch. All in all, I'm very pleased and impressed.
Old 10-26-2014, 01:02 PM
gwynethh's Avatar
gwynethh gwynethh is offline
Any interference of the new coilovers with the front hood? Someone reported they were too tall and dimpled his hood.
Old 10-26-2014, 01:46 PM
Wink Re: AMR Coilover install questions
That thread can be found HERE
See my post #6. Maybe the problem was leaving the adjustment knob in place. However, the mounting studs look too tall. I would have cut them shorter.
Old 10-27-2014, 11:55 AM
WYOSVX's Avatar
Maybe my studs are shorter. My mounting studs are fine, though they are longer than stock.
