Old 03-08-2014, 02:28 PM
Jvan Jvan is offline
need help replacing rear pads/rotor
The right rear pad wore down and scored rotor before I could replace it because of the snow/cold temp. I need to use my driveway and it was covered w/ice-snow. Near 50 degrees today so today was the day. I got the caliper out of the way and removed the rotor (not too difficult) but having difficulty w/pads. The outer pad was so worn it fell out of the caliper but I'm having a problem removing the clips and the inner pad. I need some advice/instructions so I don't damage the clips. Help!
Old 03-08-2014, 06:34 PM
edren1 edren1 is offline
Re: need help replacing rear pads/rotor
Soak it down with oil near the clips and then pry it out of the slot. If you mess them up rockauto sells then for under $10.
Old 03-09-2014, 09:32 AM
thanks,I'll soak t now and try after lunch. Rockauto is a good source but I want to drive it sooner than later. But your right,in that clips shouldn't be that expensive. It's Sunday and most local auto stores are closed but there are a few that are open if I need to replace it.
