Old 12-21-2013, 10:38 AM
ShaneHobson ShaneHobson is offline
ID my ECU please
Pulled the ECU from my parts car to swap into Daniel's car to troubleshoot his problems and noticed that the RAM was socketed and had a handwritten sticker on it. This is different from Daniel's so we're wondering what the difference might be.
My parts car is 1992 JDM. I think Daniel's is the same.
A couple of photos are attached.
Inscription on the sticker is
F23AYD06
I've d the number, but no hits.
Old 12-21-2013, 11:21 AM
dragoontwo dragoontwo is offline
Re: ID my ECU please
That is a TSB ROM that Subaru had installed at some point.
'92 SVX LS Pearl White - 6mt
Old 12-22-2013, 01:11 AM
How is the TSB ROM different from standard ?
Why would it have been replaced ?
Old 12-28-2013, 12:24 PM
subaru issued new roms to correct drive ability and starting complaints. i believe that rom is to correct a rough start when cold symptom.
Current Stable:
1992 SVX
1979 K5 Blazer Cheyenne
1967 Chevy C20
1953 Chevy 210
1969 Plymouth Satellite
1949 Chevy Thriftmaster
1959 Chevy Apache
1951 Chevy Stepside
1969 Chevy Camper Special
1978 Ford F150 w/ stroked 460
1986 Volvo 740 turbo wagon
1999 GMC 2500 Creep Van
1994 Impreza Outback
Old 12-29-2013, 02:00 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Shane TSBs (Technical Service Builds) - were quite common in USA/Canada - less common in the rest of the world.
I remember seeing a complete listing here some years ago, along with explanations.... maybe someone can point to where they are to be found?.
Most TSBs were done free of charge - due to legal requirements relating to service or safety regulations.
Old 01-08-2014, 08:56 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
That looks like a USDM ECU (label D1 or M7), not a JDM (label D2).
The JDM ECU doesn't have the little daughterboard with the atmospheric pressure sensor on it. The TSB rom chip is typically only present on USDM vehicles.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
