So yesterday while running errands, my car decided to drop dead.
Basically, I turned the key to start the car and everything turned off as if a breaker had flipped. No interior lights come on when I open the door, and my clicked doesn't work. It's as if the battery is disconnected. I checked just about everything and everything seems ok on the surface. -Fusible link is intact. -All fuses are intact. -Battery is fully charged. -Battery connectors are clean with no corrosion. -All ground cables and other power carrying cables have full continuity. -Switched around all my relays in the main fuse box and nothing. There's no voltage to any fuses when I put the key in the On position either. I haven't checked the ignition switch yet, and I am going to go through all the power wiring in and around the battery and fuse box. Anyone have any ideas what could be wrong? ![]()
1992 Dark Teal LS-L w/ 165k+ miles (traded ![]() Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs ![]() 2001 Black Toyota Sequoia (hauler/daily) 1992 Blue Toyota Cressida (drift car) 1992 Red Toyota MR2 (weekend/track day car) Last edited by EdWindows; 12-18-2013 at 12:13 AM. |
Re: No power whatsoever
Do you have +12V on both sides of all six fusible links? I read that you don't have voltage to any fuses; the fusible links are the front line, though. If you're not getting power that far, given that your battery's ground terminal does connect to ground, the lead from the battery to the fusebox is pretty much all that would disable everything.
Disclaimer: The above post is on the internet. Last edited by LetItSnow; 12-18-2013 at 08:53 AM. |
