Old 11-12-2013, 10:24 AM
The Molinator
How much is my 1995 SVX AWD L worth .. AS IS!
Since my "free parts source" dried up.. for my necessary (new) head gasket repair on recently rebuilt engine.. YIKES! .. I'm seriously considering selling SVX as is.. ???
What is it worth? You can see the mods on my signature below. just needs a head gasket.. .
Please give your BEST GUESS? (West Coast of course..)
Thanks, Jim
P.S. 236K total miles .. New "rebuilt" low miles engine.. all gaskets (incl head).. head bolts.. water pump.. oil seperator.. timing belt (ebay) kit.. thermostat.. coolant temp sensor... Ran great til head gasket leak (heats sl on long or hot trips).. I have head gaskets and many extra parts.. like HD headlamps and wire harnesses, AT pan gasket, bulbs, miscellaneous studs, bulbs
Jim
Old 11-18-2013, 12:10 PM
kwren's Avatar
kwren kwren is offline
Re: How much is my 1995 SVX AWD L worth .. AS IS!
Maybe nothing...
Keith
Sorry. =(
Old 11-18-2013, 12:43 PM
Svx95's Avatar
Svx95 Svx95 is offline
eg33svx95
Post pictures of interior and exterior of car it might just become a parts car, taking into consideration that a head gasket job runs between $1,500-$2,000 that might leave the car at no value as a whole. If I was still living in California I would pick it up!
Sam
Brilliant Red 95 SVX L AWD 149K miles - #904/1801, 08 STI 6MT with DCCD & VSS, ACT SB10 HDSS, 6MT bushings, DW200 Fuel pump, 17x7.5 VX-SCYTHE Wheels, 17x8 BBS STI Wheels,PERRIN CRANK PULLEY, 911 Turbo oil filter,$15/15min MOD & $20/20min Mod, Brontrager WORKS 22mm RSB w/ QS component endlinks, SS Brake Lines, DDM TUNING 6000K HID LOWS, Hella Optilux Extreme Yellow Fog Lights,Window scratcher fix, JDM Clear Corners
Old 11-18-2013, 01:24 PM
You're looking at $1000.00-$1500.00 at best.
Old 11-20-2013, 09:31 PM
Scoobyru's Avatar
Scoobyru Scoobyru is offline
Thanks, Jim
if you decide to part it out let me know. there seems to be a few items i would be interested in. thanks
1992 Dark Teal LS-L 237k #103994 (Sold)
GC8 Nardi Steering Wheel/
Crossed Drilled Rotors/
18" Exel Evo Wheels/15min Mod/
6k HIDs/ECU Crush Mod/
Power Mode Mod
1997 Brilliant Red LSI 151k #100109
PWR AU Radiator, Stebro Catback, Hella Supertones, SS Brake Lines, Cross Drilled Rotors, QC, Power Mode Mod, SSR GT3 Wheels 18x8 et35
1997 Ebony Mica LSi 177k #100321
