Rust Removal Time!
Alright, I'm attacking this rust and nipping it in the bud. I know the process and have all the tools needed (still need paint, but it's in small discrete areas so I'm not going to be a huge stickler over matching it 100%), but most of it is under the side panels on the doors. Obviously those need to come off. Is there a how-to to remove them? I don't know how to attack them, and I don't want to break anything. Also, I'm assuming the brackets inside have rusted away as well, would anyone be able to supply the part numbers? I will be taking off all 4 of the fiberglass panels. And no, there are no holes from the inside, I've removed all 4 inside panels to check to make sure. The driver's door has some rust on the inside but it's not bad. Any other suggestions, shoot away!
1992 Pearl White LS Owned since 2009 175k Miles STi Airlift Performance air suspension 2005 WRX manual swap Rear wheel drive ![]() K-Staff front bumper Delta Speed side skirts JDM clear corners Smallcar grille Subaru XT steering wheel Subaru XT shift knob First bagged SVX in the world Worlds first SVX on air suspension. Custom made (by myself) spare tire subwoofer. |
Re: Rust Removal Time!
Hi, maybe you can find something by conducting a search (e.g. for repair on window opener). I only took the pannels from the doors off. To do so you need to remove the inner trim.
There is a screw you need to remove, which is hidden by a plastic cover (beyond the door release lever) the cover can be removed with a flatbed screwdriver. Then there are two more screws beyond the textile cover at the bottom of the little bay behind the inner door handle. And finaly a screw openly visible next to the A-column. All other fixing points are clips, just pull carefully. Then you need to remove a plastic foil to get access to the holes in the metall door inner side. They give access to the nuts (about 5, dont know for sure), which keep the outer pannel in place. In addition there are clips. The clips broke, when I removed the pannel. Good luck! (This far I did not find a way to stop the rusting issue, I think its based on a constructional flaw.) Marcus |
I did do a few searches but couldn't come up with anything. I have taken the door and rear inside panels off a handful of times, so that's no issue for me. So just those 5 bolts inside and it should pop off? I bet the rear are similar. If anyone else has part numbers or some pointers, shoot away
Go here.
http://www.phantomotaku.com/SVX/MSA5...d_exterior.pdf Pages 102-104 have the complete side garnish and rear garnish removal procedures Here is the component overview: Download and save this particular manual. I covers every body components and how to remove, repair, replace, etc. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ... 203,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . |
Thanks John, that's the exact picture I remembered from a while back, just couldn't find it. I'll start attacking this today, and maybe make a how-to since
There isn't one yet ![]()
If you have rust behind the plastic door panels you can almost guarantee that the same is happening behind the rear quarter panels. You remove those by undoing the fasteners behind the rear seat panels below the window. Very good directions in the manual mentioned above. Be careful not to twist them or you will have trouble with fit when replacing. is the hold the warp.
Peter ART Cryogenic/Slotted Rotors, Stainless Steel Brake Lines, PWR Radiator, Tranny cooler, Stebro, Earthworm's Poly Differential/front & rear swaybar bushings, Koni Inserts and Mychailo SVX Sport Springs all 4 corners, Indigo Blue paint. Liquid Silver Wheels. |
Mike, Eric and myself came to the conclusion years ago the door rust is formed by the horrible design flaw of Subaru adding foam strips behind the garnish which in turn holds water to rot the door out. The best fix is to remove the plastic panels, fix the rust right, remove ALL foam strips as you dont need them, and I put undercoating on the metal bar for assurance. That's the only way to fix it.
How would you ever get the panel off in future in the event you needed another repair?
Don't even run silicone, just nothing. I removed them when I painted mine years ago and its fine. The seal does nothing but hold water.
All you need to do is to run a razor across it. Personally I would not seal it.
Father of 5 sons and 1 daughter Subaru SVX for fun Hyundai Veracruz for the wife. Susuki SX4 for my older son Ford Ranger for work Mercedes Benz Sprinter for vacation trips, EZ GO Golf cart for driving kids around gated community. |
The plan all along was to prime it and then absolutely smother it with spray on undercoat. What does it matter? I'll never see it. I'm going the door panels and the rear panels. I don't think I'm going to even worry about the little panels in front of the door, they seem fine. I can hear a crunch when I press on the side panels.
Oh, but be sure to get the new metal pieces. They're really cheap anyway and there's no way of cleaning them up effectively. And if you did, you'd spend a hell of a lot more than $25 worth of time on each piece or whatever they are new. I'm not kidding, they really are dirt cheap. ![]() Last edited by 1986nate; 06-13-2013 at 09:42 PM. |
Took my driver's side door garnish off to figure out why it isn't staying in place at the bottom. Door is solid, but the panel has a definite curve to it when off. It flares at both ends.
Any Ideas on how to correct this? I was wondering if some 2 sided tape like 3M 2-way adhesion tape, vertically near the bottom might work to hold it snug. Am going to replace the retainer bar thing at the top that bolts & snaps onto the door. Is this black stuff supposed to be here? Or is it leftover from a previous paint job hack? It's hard and brittle like plastic. Any idea on how to remove it if it's not supposed to be there? ![]()
To answer my own question and let others know; that black blob is panel bond. The shop that painted the car used it as an adhesive to try to hold in the garnish, which was incorrectly installed. It obviously failed. The only way to remove it is to GENTLY heat it and slip something wide behind it to pop it off as it softens. (A plastic putty knife or similar.) Get things too hot and the paint will be damaged.
