R134a conversion
This weekend I picked up an R134a compressor and drier since my old compressor is broken and runs on R12. I'm planning on emptying the system and installing the new parts and converting it to R134a before it gets above 70* here.
Now since I'll be converting, I'll have to use the PAG oil for my lines and evaporator, but I still have whatever R134a oil is sitting in my new compressor and drier. Question is can I mix the two oils or will I have to by a good amount of PAG and flush out the entire system?
1992 Dark Teal LS-L w/ 165k+ miles (traded ![]() Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs ![]() 2001 Black Toyota Sequoia (hauler/daily) 1992 Blue Toyota Cressida (drift car) 1992 Red Toyota MR2 (weekend/track day car) |
Re: R134a conversion
Anyone...?
My understanding unless you can change out/flush out everything you should use mineral oil, wont cause any reactions with the R12 stuff.
