Old 03-04-2013, 09:41 PM
tiv0's Avatar
tiv0 tiv0 is offline
svxless
Fuel Level Gauge Dim
The lights in my instrument cluster are all uniformly bright except around my fuel gauge. Does this look like a bulb may be out behind it?
"D" does not illuminate on the dash, and I found the part no. for that bulb (85066PA030), does anyone know if the bulbs behind the fuel gauge are the same part number?
Trevor
Avondale, AZ
1992 LS-L Liquid Silver 126k "BXR6" Sold 3/23/13
1992 LS-L Claret 178k totaled 10/26/09
1987 BMW 325is
60% of the time it works, every time
Old 03-05-2013, 11:04 AM
kjoyes kjoyes is offline
Re: Fuel Level Gauge Dim
I recently, replace my Drive (D) light bulb on my gauge cluster and while back there I exchange the bulbs that I used the least like bulb 1,2 and 3 with the one that are used the most like Park(P), reverse(R) and (N) Neutral.
And the new bulb went in D.
They are long and slender blubs. Do a search on (gauge cluster) on here. No there not the same bulb.
Old 03-05-2013, 01:02 PM
Huskymaniac's Avatar
Uses the ignore feature
How long did that take you?
Tony
Old 03-05-2013, 05:14 PM
30 mins the longest part is when you order the bulbs from subaru to get them.
so i would order the bulbs ahead of time so you dont have to have your cluster out of the car for 2 weeks
i used a 9 volt battery to test each of the bulbs soldered wire lead to the battery for testing purposes.
Old 03-05-2013, 07:54 PM
Wow, you got the dash apart that quickly?
Tony
Old 03-06-2013, 08:44 AM
It's not the whole dash, just the cluster that has to come out.
Old 03-06-2013, 11:03 AM
Yeah but that's a real cluster...no?
Tony
