Old 01-03-2013, 03:01 PM
Subie59's Avatar
Subie59 Subie59 is offline
94 SVX LSI Teal
Power steering pump?
Hard to steer at slow speeds and Squealing sound coming out of engine. I figure it is most likely a power steering pump or something. Anyone else have similar problem??
94 SVX LSI
2001 LegacyGT (daughter's ride now)
2005 Legacy outback XT (wife's car)
all stock and likely staying that way for now
1981 Datsun 280zxturbo summer toy
Old 01-03-2013, 03:31 PM
Re: Power steering pump?
I'd check the tension of your accessory belt, may be too loose. Also, the rubber gasket underneath of the PS fluid reservoir is most likely brittle, replacing that has solved this same issue for many members.
Old 01-03-2013, 04:05 PM
Subie59's Avatar
94 SVX LSI Teal
Thanks. Might be simpler than I hoped.
94 SVX LSI
Old 01-03-2013, 04:45 PM
Check the crankshaft pulley to see if the rim is slipping on the rubber, between two parts.
Old 01-03-2013, 11:13 PM
My guess is the o-ring.
