Old 01-24-2012, 02:55 PM
B 4 You's Avatar
B 4 You B 4 You is offline
#lolsvx
Electrical problem. :(
I was driving around today (unsuccessfully) job searching when i noticed my battery, stop lamp, and parking brake lights all came on at the same time. They were really dim though, as I stepped on the throttle (increasing battery voltage) they dimmed further and shut off. Then as soon as it went to idle, they were back on. It idled fine, the headlights weren't dimming of flashing, and I drove back to campus without any problems. The ABS light also started coming on, also dimming/brightening with voltage change. My first inclination is the alternator. Could it be worse than that? I thought all the lights in the Christmas tree would come on if the alternator was going.
If it is the alternator, how big of a deal is that to change? Could I do it myself? Would you do it yourself?
1992 Pearl White LS
Owned since 2009
175k Miles
2005 WRX manual swap
Rear wheel drive
K-Staff front bumper
Delta Speed side skirts
JDM clear corners
Smallcar grille
Subaru XT steering wheel
Subaru XT shift knob
First bagged SVX in the world
Old 01-24-2012, 03:15 PM
Uncamitzi's Avatar
Member #447
Re: Electrical problem. :(
Check your belt tension.
That's all I got....
Mitch Hansen
"uncamitzi"
This is a Dark Ride
Old 01-24-2012, 03:23 PM
could go to your local auto parts store, they will usually check your charging system for free. if you do need one buy one from maniac and put it on yourself. it's very easy to do. if you are charging ok then you may have another issue, could be anything from bad ignition switch to a loose battery cable. i would check the charging first since it's most likely given your description.
Old 01-24-2012, 03:24 PM
httrdd httrdd is offline
Alternator is a really quick change job and can get one at a good price. Loosen up the serpintine belt pulley, unbolt and unplug. Make sure you disconnect your battery.
99 OBP LGT Eg33 swapped.
92 pearl LSL for parts.
Old 01-24-2012, 08:09 PM
If it is the alternator, how big of a deal is that to change? No big deal
Could I do it myself? Yes
Would you do it yourself? Yes
You can find the complete how-to instructions for the alternator removal nd reinstall in the how documents HERE
Should not take you more than 30 minutes to replace.
Old 01-24-2012, 09:34 PM
B 4 You's Avatar
#lolsvx
That seems do-able for me. How fast do you think the Maniac alternator can get to me? I was planning on going somewhere this weekend. I just bought a new battery a month ago, and I really don't feel like destroying it.
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 01-24-2012, 10:33 PM
Call Christian a Maniac tomorrow (972) 557-5768.
I don't think it can be done in your time frame. Tomorrow is already Wednesday.
Even, if they had one ready to ship tomorrow (which would be one of the stock 95A units), any savings would be eaten up by UPS overnight ($130.00) or second day air ($77.00) charges. Christian may be able to get you a better rate.
I know from talking to her that ground shipping from Dallas is 3 days and runs her about $19.00.
Old 01-25-2012, 05:08 AM
dcarrb dcarrb is offline
Both of mine displayed exactly the same symptoms and replacing the alternator was the fix in both instances. I'm no mechanic, but changing an alternator on these things isn't much more complicated than changing the oil.
Not to contradict good and popular advice: If you decide against Maniac, the alternators I bought were remans from Advance Auto, which they had for me within 24 hours, and I've had no trouble from either.
dcb
Old 01-25-2012, 07:43 AM
B 4 You's Avatar
#lolsvx
I'm going over to Advance Auto when school is out to get my alternator tested. If it is bad (I'm assuming it is) I will most likely buy a Maniac one. Mainly because they have such high ratings and popularity here. The ones at Advance are much more expensive now too. hHopefully someone can bring my some tools this weekend, because all I have on hand is a pen screwdriver.
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 01-25-2012, 08:14 AM
dragoontwo dragoontwo is offline
What about the tool kit that comes in the car that lives in the spare tire area? It should be able to remove it.
'92 SVX LS Pearl White - 6mt
Old 01-25-2012, 11:14 AM
B 4 You's Avatar
#lolsvx
I took it out because of reasons.
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 01-25-2012, 05:32 PM
B 4 You's Avatar
#lolsvx
Took it to Advance today, alternator is dead. Ordering one tomorrow. Oh and John, I called Christian, she was really nice, but she said shipping it expedited isn't worth it. She said it should take about 4 days to get to me, and that should be fine. Thanks for the help gentlemen!
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
