Old 08-27-2011, 01:03 PM
Troubleshooting Electrical Problems
So over the years I've been able to fix mechanical issues on the svx, i.e. water pump, timing belt, radiator, suspension, a/c...etc.
I have not however developed an understanding of troubleshooting electrical issues. I've been pretty luck so far I suppose. However, now I am experiencing what is likely an electrical issue with my a/c system. As some may have read in my other thread I have replaced all components throughout the a/c system, pulled and held a vacuum however the system will not charge. Both the low and high side pressure readings are the same. I was told by the a/c technician that rebuilt my compressor that the likely source is a constant current to the relief valve (the svx manual indicates that the solenoid valve control controls the relief valve).
My problem is to troubleshoot it I need some sort of resistance guage. I have never used one although have seen technicians use it and it appears they stick the "nodes" in the wire to measure connectivity, current and resistance. I am uncertain as to whether there is a particular place to measure these readings...the manual indicates to measure a specific numbered terminals (again at a loss on this one). Does anyone have any suggestions on the type of "resistor" to buy? Again I apologize for my ignorance on this issue I'll continue researching in the meantime, thanks in advance. - Chris
Old 08-27-2011, 01:17 PM
Tapani Tapani is offline
Re: Troubleshooting Electrical Problems
Is there a definition file for the A/C controller to be used with something like the ECUtuner?
This is a current topic for me too - my A/C quit producing cold last week even though the compressor runs. It's been fairly low performance thru the summer - even after recharging.
If someone knows exactly how the variable discharge compressor is controlled it would help a lot. My high side was a bit low and the low side kinda high - but it would be great to know how to force the compressor go on "full discharge".
Tapani
Old 08-27-2011, 11:40 PM
http://www.phantomotaku.com/SVX/MSA5...3_Air_cond.pdf
Tapani
Old 08-28-2011, 08:26 AM
longassname's Avatar
Just some dude.
Tapani,
You can make your own definitions file to use the ECUtuner interface and software to perform diagnostics on your AC. I gave Phil Skuse, that's the guy with the gearshift map thread you posted in recently, the firmware from a select monitor cartridge a couple or few years ago and he pulled all the locations for all the select monitor functions off of it. I think he has a thread on that here somewhere. I just checked and see he has the locations for the AC diagnostics on his website here: http://www.alcyone.org.uk/ssm/aircon.html
I think he has the conversion formulas posted in the thread on the select monitor cartridge. His screenname here is B3lha
Old 08-28-2011, 10:36 AM
Great, thanks a bunch.
I will look into it !
Tapani
