Oil filter study
Just found this link to a relatively new oil filter study:
http://www.gmtruckcentral.com/articl...lterstudy.html The highest rated filter that offers a filter with the larger size (Porsche 944) is the K&N. For the standard size filter, one could probably find filters from the other highly rated options. The Fram Xtended Guard rated suprisingly high.
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything Last edited by Huskymaniac; 06-26-2011 at 07:57 PM. |
Re: Oil filter study
Thanks for the link - very interesting study. Makes me think about going away from the purolator pure one's I've been using for years.
The K&N looks very similar in construction to the mobil one.....
Very interesting. Thanks for the link. I will rethink what I use in the future as well. The Fram Xtended Guard being the best of all is very surprising.
Good info. ThanQ.
Peter ART Cryogenic/Slotted Rotors, Stainless Steel Brake Lines, PWR Radiator, Tranny cooler, Stebro, Earthworm's Poly Differential/front & rear swaybar bushings, Koni Inserts and Mychailo SVX Sport Springs all 4 corners, Indigo Blue paint. Liquid Silver Wheels. |
I'm glad people are finding this informative. It has actually pushed me toward increasing my OCI. I am thinking of pushing it to 6000 miles and here is the reasoning.
Subaru suggests an OCI of 7500 miles or 3750 miles if one drives in harsh conditions. Harsh conditions are extreme cold or heat or driving in a dusty environment or making lots of short trips. The only thing that applies to me is the extreme cold or heat and that is only for about half the year. Splitting the difference gets me 5625 miles. If I am thinking about longer OCIs, I will only do it if I use a synthetic like Mobil 1 which claims to be good out to 7500 miles regardless of conditions. So, really, my oil should be in good shape beyond 5625 miles if I am using a synthetic. While the oil may hold up in terms of not becoming excessively oxidized and acidic, there is still the issue of contaminants finding their way into the combustion chamber and, hence, the oil and oil filter. That is why people still change oil filters when they switch to synthetics and extend their OCIs. But the larger Purolator and K&N filters are 60% larger than the stock filter. 60% more miles would equate to 6000 miles if the reference point chosen is the lower 3750 mile number. So, given that I don't drive in extreme conditions year round, I am switching to Mobil 1 and I am using a 60% larger filter, I think a 6000 mile OCI is fine.
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything |
I take it Chevy does not brand their own oil filters like Subaru does?
I believe GM's brand would be the "Delco" but things may have changed.
as for Napa filters are WIX and most others are primarily FRAM
Tranny goes in, tranny comes out, tranny goes in.....AW ****, tranny comes out.... |
I don't spend a lot of time above 5000 miles and what is Mobil 1 inferior to? I have looked at a lot of oil data and Mobil 1 is pretty good by most accounts. It isn't up there with Redline or Amsoil but it is better than most of the typical dino oils. And I think it rates better than most of the commonly available synthetics.
I'm also interested in your reasoning.
I have attached one of the best summaries of motor oils I have ever seen. The rankings are grouped by oil weight.
