Old 06-14-2011, 10:19 AM
sheldonmaul3 sheldonmaul3 is offline
SVX towhitch?
Im looking to get a custom towhitch on my 92 svx. At one time it will tow no more than 900 lbs with jetski and trailer, and with the AWD and the few modes that i have on it im guessing it will have no problem.
Any ideas or suggestion?
Old 06-14-2011, 06:23 PM
Stevebsy's Avatar
Stevebsy Stevebsy is offline
Administrator
Re: SVX towhitch?
You will have to make the hitch yourself, as nobody offers one commercially.
I recently made one based on the plans that Tuzem and ConnSVX used. Do some searching for trailer hitch and you will find pictures.
Basically you need to buy a 2" square tube, a receiver tube, and some 2" x 1/4" flat bar, and some 1/2" or 3/8" bolts to put it all together. If you make it yourself you can do it for < $100.
I'll post some pics of mine if you like.
With 4.444 gears it had no trouble towing a u-haul 4x8 trailer with a bunch of my junk inside. Though I did have to remove the waterfall grille to get more airflow as the temp was starting to creep up sometimes, though it was a high 90's temp day when that happened. After I took the grille out it was fine. With stock 3.54 gears you will probably be fine too, just a little slower to get up to speed. Take it easy on acceleration and you shouldn't have much problem with 900lbs.
'20 Honda Ridgeline
http://www.x35design.com
Old 06-14-2011, 07:49 PM
Re: SVX towhitch?
Very easy to make . the hardest part is drilling the holes into the rear suspension arm. The space is cramped . I used a right angle drill. As said above .. You bend a 18" long piece of 1/4 3" wide steel plate at a 90 deg. you weld a 6" piece to the same stuff to bottom of the end sticking out .Drill a hole in it . Take a piece of the same stuff and bolt it to the 6" piece and make it long enough to reach the rear of the car between the hold downs . The square tube is cut just a 1/2 shorter than the distance between the tow rear hold downs. Weld taps to the ends of the square tube and fasten it to the hold downs then weld the long flat piece to it add the receiver and you are done SEE pictures and read this at the same time Go to my locker ans see pictures I have towed my motorcycle 70 miles on a 5X10 trailer
Old 06-15-2011, 06:05 PM
michael's Avatar
michael michael is offline
What Potholes ???
Re: SVX towhitch?
Not so sure about that. I'll have to do some searching but I think there was one available once upon a time.
Wanted: Steering Wheel
Old 06-15-2011, 06:30 PM
Re: SVX towhitch?
That looks custom to me.
Old 06-15-2011, 06:55 PM
Re: SVX towhitch?
That's the guy i got my plans from in OZ/ He just went the chrome plated look. I my powder coat mine/// can they powder coat in silver ///??
Old 06-15-2011, 07:35 PM
michael's Avatar
What Potholes ???
Re: SVX towhitch?
Not exactly the pic i was searching for. I was picturing a teal svx with a black hitch.
Old 06-16-2011, 12:06 AM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Smile Re: SVX towhitch?
Yes that's my baby - got the local guys to make it for me, give me a couple of days & I will take photos to show you guys the underneath & bolt positions.
I actually only wanted it for my bike carrier - I have only used it for towing small trailer for short distances.
Steve in NZ (1 OF 1)
Old 06-16-2011, 05:27 PM
kjoyes kjoyes is offline
Re: SVX towhitch?
Here i found one on Rock Auto made for our svx's here is the link
http://www.rockauto.com/catalog/x,ca...,parttype,1212
I dont know if i will work on all the svx like the 95-96 or 97
let me know that hitch will work. Something i would want on my 97.
Old 06-16-2011, 05:34 PM
Re: SVX towhitch?
haha, good luck with that
Old 06-16-2011, 07:35 PM
Re: SVX towhitch?
go to OLD locker and then to my locker ConnSVX go to the trailer pictures You will see it all together painted black on the bench. All that is missing is the Square tube that bolts between the hold down bolts and is welded to the end closest to the front bottom of the picture . The back is bolted to the swing arm . 5 bolts hold it on (2) int the swing arm One into the rear of the bracket for easy removal (optional you can weld it if you want ) and ( 2 ) that bolt it to the rear hold downs at each end of the square tube.
Old 11-06-2019, 09:18 AM
2times4 2times4 is offline
Re: SVX towhitch?
Sorry, but couldn't find where you were directing me to go for more info on the hitch.
Old 11-06-2019, 04:27 PM
Re: SVX towhitch?
Here you go.
http://www.subaru-svx.net/photos/use...nn%20SVX|32722
Old 11-07-2019, 05:56 AM
Re: SVX towhitch?
Thanks, that's what I needed.
Old 11-08-2019, 01:58 AM
SURTEESS's Avatar
Re: SVX towhitch?
1 OF 1 is mine - got the hitch made approx 22 years ago, mainly used for a bicycle rack....
