Old 03-17-2011, 08:00 PM
pjd7325's Avatar
pjd7325 pjd7325 is offline
Clunking
I have noticed that the svx clunks a lot when going over bumps and also the handling is not great at the front. I took the front wheels off and had a good look around. I have noticed that lower ball joint boots have split and the grease as been squeezed out ( all over the inside of the wheels!) While under there I greased up everything using silicone grease and changed the front brake bads.
Would be best to replace the lower ball joints or can you get boot kits? If so for either where would be the best place to source these parts from? I have searche eBay but no joy at the moment. There are some universal boot kits but I have no idea what size to order.
Also on a different subject, how many svx's are on the road in the uk now?
Old 03-18-2011, 01:35 AM
DJW svx DJW svx is offline
Re: Clunking
I've just had mine changed and bought them from the U.S.A. from Rock auto parts quick delivery as well you can get the CV boots as well because there was no U.K. source when I tried to get them. Buying parts from the States is dead easy and the only way to go really.
Old 03-18-2011, 02:06 PM
pjd7325's Avatar
Re: Clunking
Thanks for the information, I will check their web site.
Old 03-20-2011, 06:14 PM
pjd7325's Avatar
Re: Clunking
I have had a look on the parts web site. I cant seam to find the part. How much are they out of interest?
Old 03-21-2011, 01:37 AM
Re: Clunking
I'll have a look for invoices this evening
Old 03-21-2011, 05:29 PM
pjd7325's Avatar
Re: Clunking
Ok Thankyou
Old 04-06-2011, 03:30 PM
pjd7325's Avatar
Re: Clunking
I managed to source these from the US in the end. I did attempt to change them today but I couldn't get the bolts to shift!! Going to take to a friend who has some better tools and grunt than me on saturday.
Old 04-07-2011, 06:48 AM
Re: Clunking
I would also check your tie rods and ends for play as well.
You are replacing both front ball joint assemblies, correct?
Old 04-07-2011, 09:35 AM
pjd7325's Avatar
Re: Clunking
Hi, thanks for the info. Yes I am changing both of them. The old ones have been on there since new by the looks.
1993 Black JDM VE
