using atf in gas to clean engine
i came across an article saying you can put a quart of atf into a tank of gas and it will help clean out the engine
anyone else hear of this?
Tranny goes in, tranny comes out, tranny goes in.....AW ****, tranny comes out.... |
Re: using atf in gas to clean engine
Never know if it did anything but smoke a bit! Keith |
Crankcase, yes. Gas tank, no.
dcb |
Somehow I think the only thing that would be cleaned out is your bank account, since new catalytic converters are a bit on the expensive side.
Marvel Mystery Oil! Definitely old school.
-Bill
I wouldn't put ATF in the gas tank but I do put in a quart of it in the engine oil prior to changing out the oil and filter. It does a decent job of cleaning out the oil passageways.
If it ain't broken it, doesn't have enough features!!! '92 SVX LSL '03 4Runner '96 FZJ80 Landcruiser '90 Mercedes 300E |
I have heard of this. we do it in HMMWV's (hum vee's) in the army from time to time, but that's a diesel with no cats, never tried in a gasoline engine.
I would stick with Redline SI-1 or 3M's top end product. Amsoil's product is good too.
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything |
