Old 02-28-2011, 07:51 PM
clarkerussell clarkerussell is offline
Proactively Replacing 02 sensors... Is it a waste of money?
Hello all,
My 1996 has 115K miles and I don't think the O2 sensors have ever been changed. I have no indicators that they are defective, I was just thinking that they need to be replaced at about 100K miles. That being said, should they really be replaced proactively? Thanks in advance.
Clarke
Old 02-28-2011, 08:14 PM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
Re: Proactively Replacing 02 sensors... Is it a waste of money?
You are doing the right thing..your gas mileage should be a bit better too.
I don't normally do mine unless it throws a code. If you haven't done so, put some antiseize on the threads.
1995 Subaru Svx L / AWD
Old 02-28-2011, 09:01 PM
B 4 You's Avatar
B 4 You B 4 You is offline
#lolsvx
i need to get new ones on mine.
procrastination.
1992 Pearl White LS
Owned since 2009
175k Miles
2005 WRX manual swap
Rear wheel drive
K-Staff front bumper
Delta Speed side skirts
JDM clear corners
Smallcar grille
Subaru XT steering wheel
Subaru XT shift knob
First bagged SVX in the world
Old 03-01-2011, 04:48 AM
Put new ones on mine proactively. Figured it could only help.
Old 03-01-2011, 05:42 AM
I wait for a code. If they aren't working properly the CEL will let you know.
Old 03-01-2011, 06:24 AM
Manarius's Avatar
Manarius Manarius is offline
If you're seeing no symptoms, I really see no reason to replace them. Now, if you were having bad mpg or other engine issues, then I could justify replacement. But, "just because it's old" isn't really a good reason to replace things on a car unless it's prompted by something else, or it's something that wears out with age (belts, gaskets, etc.)
-Jason
-Obi Wan Kenobi
Old 03-01-2011, 06:15 PM
Bonestock's Avatar
Bonestock Bonestock is offline
Nürburgring Warrior!
If it aint broke, dont fix it. If it broke while you were fixing it, it needed fixin' anyway!
2010 Subaru WRX
1992 SVX LS-L 89k miles-SOLD!
KTM 250sx MX bike aka "Killer Pumpkin"
Old 03-01-2011, 08:23 PM
Jake@FAPFab's Avatar
Jake@FAPFab Jake@FAPFab is offline
11.24:1 E85
recover horsepower and drivability by switching to denso 02s.. $60 each at rockauto
Old 03-02-2011, 04:48 AM
dcarrb dcarrb is offline
I would proactively replace O2 sensors (or pretty much anything else) only if a failing O2 sensor could make me have to walk home.
dcb
Old 03-02-2011, 07:00 AM
Freeman's Avatar
Freeman Freeman is offline
Unregistered User
I just ordered a couple of those NGK's, John pointed out in another thread. Only about thirty dollars each.
Old 03-02-2011, 07:11 AM
Are there 2 or 4 O2 sensors on the SVX?
Old 03-02-2011, 10:24 AM
11.24:1 E85
3 wire 4 pin sensor
Old 03-02-2011, 10:40 AM
2 on OBDI(92-95) SVXi and 3 on OBDII(96,97) SVXi
