Old 02-24-2011, 11:37 PM
Red94Svx Red94Svx is offline
Exclamation revs drop when speeding up
when im driving say 50 mph and i step on the gas the revs drop about 200-300 revs and goes up.... why? i don't understand lolz as to my knowledge my car has been doing this since i got it but never really put alot of thought into it until now?
is it a transmission problem? (that ='s bad lolz)
Old 02-25-2011, 01:00 AM
Re: revs drop when speeding up
It's your torque converter locking up...
Your transmission is fine, have a nice day.
Old 02-25-2011, 01:36 AM
is it expensive? easy to fix? help lolz
Old 02-25-2011, 01:39 AM
No fix needed, normal operation of an automatic transmission with lockup torque converter.
Old 02-25-2011, 01:41 AM
will that make the shifts harder? cause sometimes i get hard shifts with me trans.?
Old 02-25-2011, 01:44 AM
The shifts being harder could be related to the TPS, or possibly other issues. Do you happen to have a check engine light on ever, or otherwise the "power light" flashing at startup?
Old 02-25-2011, 01:47 AM
yes, the check engine light comes on sometimes but its more of just a flash and then off... no power light blinking tho
what is TPS?
Old 02-25-2011, 01:51 AM
Check the codes for the engine first following the instructions in the how-to section of the forum and find out what the code is. It should show a stored code even if it just flashes and shuts back off.
TPS= throttle position sensor and if it is not reading right for a couple of reasons, will affect the way the transmission shifts. It also does not always throw a code.
Old 02-25-2011, 01:54 AM
so how expensive and hard of a fix would that be?
because some shifts are hard and some you you don't even relized you just shifted lol...
but anyways my svx is a FWD
does that mean every svx drops the revs like that when speeding up?
edit: what code how to am i looking for ? TCU? (maybe a link )
