Old 02-20-2011, 07:44 AM
CorSVXette's Avatar
Classic SVX
Bad Power Steering Pump?
I don't hear this noise when I first start the car but after it warms up I start to hear a rattle noise like ball bearings rattling around in the engine area. I think I narrowed it down to the area near the power Steering Pump. It appears to quiet down when I turn the steering wheel slightly. Like it appears to go away slightly when I am putting pressure on the pump/belts? Does that sound right? I also put my hand on the pump and believe that I can feel the rattle from that area. I checked the fluid and it was low so I added fluid. Don't know if I destroyed the pump because It was low on fluid. What do you think? If you think it is the pump, does anyone have a good one for sale that I can buy? Don't want to buy a brand new one if that is not the problem. If you guys are pretty certain that it is the pump, I will spring for a new one. If so, does anyone know the part number? Thanks guys. I guess I will have to find a new mechanic to install this for me since my main man YT shut down his operation.
Paul
1969 Corvette
1995 Corolla
2003 Highlander
Old 02-20-2011, 08:59 AM
SomethingElse's Avatar
word words wording
Re: Bad Power Steering Pump?
If you could get a video or a sound clip of the noise that would help.
Its difficult to diagnose without hearing the noise. If you firmly believe its the p/s pump start with replacing the o ring between the pump and the reservior.
Eric
Old 02-21-2011, 11:37 AM
pile o' wrx's Avatar
pile o' wrx pile o' wrx is offline
I just sent one of my good ones to NorthUrsalia. I guess I could part with another pump.
John
'05 STI
'00 2.5RS
Old 02-22-2011, 05:25 AM
dcarrb dcarrb is offline
Before you fiddle with the pump, be sure the belt tensioner pulley immediately below it is spinning quietly and free.
dcb
Old 02-22-2011, 05:55 AM
CorSVXette's Avatar
Classic SVX
dcb
Thanks. I think I will try this first because as I said before, the noise seems to go away a little when I turn the wheel and put "Tension" on the steering. I am not very familiar with these cars, that is why I had YT do all all my work for me. I will try to look at this myself so I have a few questions: Do I check to see if it is spinning freely with the engine off? Do I need to take anything off to get to this pulley?
Paul
1969 Corvette
1995 Corolla
2003 Highlander
Old 02-22-2011, 06:14 AM
Not running. Remove the PS/ALT belt and spin the tensioner pulley to be sure it rotates freely and silently; if binding or noisy it needs to be replaced. Not likely to be affected by turning the steering wheel; just something to rule out before assuming the pump is shot.
dcb
