What is this device under the intake?
I am removing all the emissions control devices from my H6 that is going in my 91 wagon and found this guy under the intake. I don't know what it is as it looks like an IAC by the way its plumbed but the IAC is on the throttle body. I am just wondering its function so I know if I can remove it. I don't see any wiring for it on my engine control diagrams. Also I don't want to hear any "why are you removing stuff its there for a reason and leave it" I hate emissions equipment and seeing as I am doing this as a swap with a huge harness merge I am not going to also wire all the emissions stuff back in so its gone.
Brad
1988 Firebird Trans AM, 1987 BMW 325is, 1978 Dodge RamCharger, 1989 Chrysler Conquest,(2) 1988 Merkur XR4TI 1973 Super beetle Baja Bug 2006 Chrysler 300C SRT8 1996 Buell S1 Lightning 1998 Subaru Forester 1993 Chevy K2500 |
Re: What is this device under the intake?
Those pipes make me think it's something part of the PCV system, which is something I would keep (even though it's emissions related).
-Jason (8/23/07-Present) 1995 Subaru SVX LSi (197k) Polo Green (#1102) 03/95 Mods: DDM Tuning 4500k 35w Low Beam HID, 100w H3 Bulbs, Extra Ground Cables, 15 minute $12.96 mod, svxfiles designed transmission mount ( ![]() silver BBS rims, custom power steering cooler (one that doesn't dump ATF constantly), new negative lead cable, no more third or fourth gear ![]() (1977-Present) 1977 Chevrolet Corvette (81k) Silver (12/01/2011-Present) 2005 Subaru Outback 2.5i Limited 5MT (97k) I have a bad feeling about this. -Obi Wan Kenobi |
Looks like aux. air control valve.
Subaru says it's the "Auxiliary Air Valve", for what that's worth.
2009 Volvo C70 T5 2008 Volvo S80 V8 2006 Range Rover Sport 2001 Audi S8 |
Ok auxiliary air valve is going to be gone. as for the PCV I am going to keep that stuff as its keeps the seals from blowing out just a little bit longer. LOL I am actually looking at running an electric air pump as a vacuum pump to the breathers so I don't have to pull the oily air into my intake. that or plumb in a vacuum port in the exhaust.
Thanks so much for the help guys, Brad
Somebody, correct me if I'm wrong... That piece might be influential to your cold idle.
Disclaimer: The above post is on the internet. |
From the FSM: Aux. air valve supplies by-pass air only when engine is cool. Also from the FSM: More than half the air for idling is supplied by the bypass valve.That's under the TB.
Yes you do need that one.
![]() ![]() Harvey.
No, you are not wrong. I think mine got gunked up when my PCV was stuck and it does cause a bouncy idle when cold.
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything |
The one on my SVX must stick because it sometimes stays at high idle like 3 grand till i shut if off and back on. So your saying I need it just for cold idle right? I will have to look at the ECU pin out again to see if they list it to hook it up.
Brad
![]() Harvey.
So the 91 wagon I am putting the engine in would not have provisions for that off the old engine either. I am going to unplug the one that is on my SVX and see how it starts tomorrow. If I have to start it like I do my old dodge with the throttle open just a bit thats fine by me. LOL My end goal with this wagon is a rock crawler/mudding car. I am hoping with extensive fender cutting and smashing i can fit 28"
Brad
