Old 12-28-2010, 07:58 PM
Will Will is offline
Select Monitor (ssm1/OBD1) USB Cable
I was going to purchase the ssm1/obd1 usb cable to run diag from my laptop from the link provided in the how-to documents. It has been available for the past few weeks. Now when you hit the jump for the link it says access denied and the usb cable is as if they never had it. Does anyone know what happened? Also any reviews on it would be appreciated.
Old 12-28-2010, 08:36 PM
Geoff's Avatar
Geoff Geoff is offline
Send a message via ICQ to Geoff Send a message via Yahoo to Geoff
Re: Select Monitor (ssm1/OBD1) USB Cable
http://www.evoscan.com/evoscan-gps-o...ubaru-vehicles
Old 12-28-2010, 08:39 PM
Good stuff Geoff! Thanks.
Old 12-28-2010, 08:43 PM
Why are these things so cheap, are they accurate?
Old 12-28-2010, 08:45 PM
Geoff's Avatar
Don't know, but this is pretty much THE place to get them now.
Old 12-28-2010, 08:49 PM
I think I'm going to go ahead and get one unless someone could possibly give me a viable reason not to!?
Old 12-29-2010, 10:27 AM
Could someone please give me a product review on these USB cables. I want to at least be able to read thrown codes accurately.
Old 12-29-2010, 11:00 AM
Geoff's Avatar
I've got one. All depends on what software you're using. I'm working with Evoscan on some questions ATM.
Old 12-29-2010, 01:34 PM
I can just download the evoscan software? Could I get a link possibly?
Old 12-29-2010, 03:44 PM
Geoff's Avatar
Same site the cable's on....
Old 12-29-2010, 05:28 PM
Been out of the game for a little while but when I was working with Evoscan, it was not possible to use it for basic code diagnostics... It gives you a read-out of data parameters and allows you to datalog and dump the ECM's memory. I do not see most people having a great use for this
Old 12-29-2010, 06:21 PM
I think this is exactly what I needed to hear Tom!
Old 04-03-2011, 12:44 AM
Gamesy's Avatar
Gamesy Gamesy is offline
i know this is resuurecting and oldie but is this cable the same as the one on http://www.alcyone.org.uk/ssm/sma.html
Old 04-03-2011, 02:34 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Yes. It is the same.
Evoscan works perfectly with the cable from alcyone.org.uk, You can also download the Evoscan definitions file for SVX from there.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 04-03-2011, 09:53 AM
Gamesy's Avatar
ok good to know i'll try making my own it not i'dd buy the evoscan one
