Old 10-30-2010, 11:01 AM
Stilor's Avatar
Stilor Stilor is offline
Rear headrests - removable?
I need to remove one of the headrests in the rear so that a child seat is positioned properly. I didn't notice any latches, or something that holds it in place, except for a small metallic lever - that appears to be stuck. Is it the lever for releasing the headrest?
-- Alex
1996 SVX LSi "Used To Be Black"
2010 Ford Expedition XLT EL 4x4 "Silver"
Old 10-30-2010, 11:15 AM
NeedForSpeed NeedForSpeed is offline
Re: Rear headrests - removable?
Yes, reach in with your finger, it should move one way or the other way. Doesn't move much, but it will release the headrest. Lever is only on one of the two headrest posts.
Special Thanks to Our Friends and Sponsors:
http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/
http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston
"QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works,
'92 Subaru SVX LS-L Claret ORIGINAL OWNER
'92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~
'92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143
'92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117
Old 10-30-2010, 11:40 AM
Stilor's Avatar
Thanks! It was a bit stuck, I didn't want to apply more pressure in wrong direction
-- Alex
Old 10-30-2010, 12:05 PM
It's just a spring wire,
you may have to bump the headrest up or down to free the wire in the notch of the post, then the wire should move easily when you reach a finger in to push/pull the wire. Good luck
