Old 10-01-2010, 02:39 PM
SVXyGirl's Avatar
SVXyGirl SVXyGirl is offline
*sigh* rust...
Drivers side rear quarter panel. Just above the rear wheel and by the tail light. I've done/helped to do some body work in the past, but that was on old farm trucks. Anyone have some good tips for fixing this? Since it is my [favorite] SVX, I want it to be done right. I don't have the money to send it to a shop right now.
Side note: I believe that this car was rear-ended at some point before I bought it (I'm the 2nd owner). So it looks like whoever put it back together did a half-@ss job. So I'm also worried at the same time what I might find.
soooo...if anyone also knows of a shop in the Del/Mar/Va area with fair prices...
Pics:
Rebecca
06 Suzuki Boulevard M50 7k
Past SVXs:
96 SVX Bourdeaux LSi (Sold)
Old 10-01-2010, 03:40 PM
Re: *sigh* rust...
Damn Rebecca, that's sad to see. I had the same "surprise" spring on me with my silver (also my favorite).
Hopefully you can find someone near you to do a good job.
Old 10-01-2010, 08:43 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
Re: *sigh* rust...
I'm in the process of doing the same thing on the silver. I'm getting some rust right over the wheel well and working on getting rid of it. I didn't realize how big of a pain body work is. I have been wirewheeling away at it and trying to get it down to bare metal to prime. Are you able to see that part of the panel from the inside?
Check to see if it it's also rotting from behind, which really would be a determining factor in what to do next. I think I may have to get my fenderwell cut and a new piece welded back in (it's that bad )
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 10-01-2010, 10:24 PM
Green1995SVX's Avatar
Re: *sigh* rust...
It looks like you have quite a bit of filler in that quarter panel.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 10-01-2010, 11:56 PM
alltrac alltrac is offline
Re: *sigh* rust...
Quite a bit of orange peel too.
Victor
Old 10-02-2010, 12:09 AM
svxAL's Avatar
svxAL svxAL is offline
more windows then a minivan..
Re: *sigh* rust...
What u need to do is determine how bad the rust is. If it is bad aka rusted threw or bubbling on the inside) your going to need to cut it it out and weld a new panel/piece in. ootherwise grind it to get rid of the crack and or rust in this case grind till there is bare clean metal. Then re fill it using some evercoat filler. feather it out and prime it, then block it out , then scuff the whole quarter with gray or red scotch brite then paint it. done deal.. and dont worry if i had bady work done/ has filler in it I put filler in cars with 5 10 miles on them all the time at the dealer I work at. Just save that baby before she gets worse.. let me know if u have any ? and ill be sure to answer them!
*1994 5 speed, Barcelona Red W/ Black ebony pearl top FWD*murrano wheels,lowered with motorsports springs drilled and slotted rotors 20% tint,swapped in leather seats,full exhaust cat delete,15 min mod, red F&R energy bushings
Old 10-02-2010, 12:42 AM
Re: *sigh* rust...
Or just travel to the midwest and have him do it
Old 10-02-2010, 04:53 AM
Tim's Avatar
Tim Tim is offline
Re: *sigh* rust...
Do most places prefer to not cut and weld? What type of cost is to be expected? 1000 dollar range for cutting, welding, paint and blend the panel plus the cost of panel?
Tim
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 10-02-2010, 06:05 AM
dcarrb dcarrb is offline
Re: *sigh* rust...
Unfortunately, any rust in the quarter panels (especially right behind the wheel openings), rocker panels and such ain't likely to be surface rust... it's rotting from within. Proper repair will be costly. Generally-speaking, body-filler repairs of rust perforation are temporary patches.
dcb
Old 10-02-2010, 08:44 AM
SVXyGirl's Avatar
Re: *sigh* rust...
That's why I believe it was rear ended. That and you can see a difference in paint not too far from that area that covers the whole back end. The color has more gold in the paint than the stock Claret. Also the bumper is fading to hell. Has been since before I bought it. I'll take a look behind to see what I find. This car has been needing a paint job for awhile and I've been trying to fix everything on the inside before I paint the outside.
My father used to professionally restore Mustangs, so he knows all about rust. He has the equipment to fix it too. So I was hoping to get a little insight on things to watch out for SVX-wise when repairing. Maybe share any tips as well. But, in the end this maybe a sign to just paint/fix the whole outside at once.
Mike621 want to share tips on completely restoring a Claret?
Rebecca
Past SVXs:
Old 10-02-2010, 10:56 AM
Manarius's Avatar
Manarius Manarius is offline
Re: *sigh* rust...
I have about a 3x3 patch of rust near the pinch weld on the rear passenger side wheel well and my body guy wanted like $230 to fix it.
-Jason
-Obi Wan Kenobi
Old 10-02-2010, 03:14 PM
Re: *sigh* rust...
Rebecca,
I foresee liberal usage of a grinder, a welder, and a sheetmetal patch in your future.
Cut until you get to clean metal.
Old 10-12-2010, 09:27 PM
pixelpusher pixelpusher is offline
Re: *sigh* rust...
Unfortunately it's the tip of the iceberg. Mine did not even look that bad and I had to replace both quarter panels, rear wheel wells, and one rocker panel part. I spent over 5 grand. i know, I'm nuts!
At least the rest of the car was rust free. The rear wheel area seems to be the weak point on these cars.
