Old 09-23-2010, 06:22 PM
subbieatnz's Avatar
Subaru debuts 3rd gen Boxer
Boxer lovers, the next chapter in your love affair has just begun. Fuji Heavy Industries, parent company of Subaru, has introduced the latest, third-generation boxer engine that will relieve the second-gen after 21 years of service. This is a brand new lump, not a rework, and FHI has built a factory just to produce it.
The displacement, bore and stroke have all been increased, and it will be available with four cylinders in 2.0- and 2.5-liter displacements. The intake ports have been redesigned, lighter pistons and connecting rods offer reduced internal friction, and separate cooling circuitry for the block and the head are some of the changes that have resulted in a lower emissions and a ten percent increase in fuel efficiency. No power figures are being quoted yet, so we'll have to see how it measures up when it finds its way into production engine bays.
This new boxer will be Subaru's primary engine, and will first be seen in the Forester.
http://www.autoblog.com/2010/09/23/s...linder-engine/
1989 Vortex 6 Maroon
1983 RX Silver Grey
Old 09-23-2010, 07:21 PM
NeedForSpeed NeedForSpeed is offline
Re: Subaru debuts 3rd gen Boxer
I saw an article about the engine several weeks back, chain drive. What is not known, but believed, is that the engine has close bore spacing like the 3.0L. Very interesting, thanks for posting the pic
Special Thanks to Our Friends and Sponsors:
http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/
http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston
"QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works,
'92 Subaru SVX LS-L Claret ORIGINAL OWNER
'92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~
'92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143
'92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117
Old 09-23-2010, 09:37 PM
ShiuludeSVX's Avatar
Slickness. Now for the bigger bores.
The Worm
_______________
June '91 Claret LSL #1733, Enkei RS-5's x 16", Original Paint, accompanied by Beautifully speckeled Front Bumper, Sony Audio Components, Small Car Shift Kit, "How to" Hood Lifts {Perfect}, "15 Minute Suspension Mod"
Motorsport Floor Mats. Perma-Cool External T. Filter, New Front Axels {1/2008}. "Classic Radiators" unit "$36 coil alternative" and Tranny rebuild at 287k 8/2012
'05 Infinity G35 Coupe.
No Mods, 33K Miles
Old 09-23-2010, 09:45 PM
Still 2.5L, bore and stroke changes are marginal.
If you want bigger bores, open up an EG33
Old 09-24-2010, 08:39 AM
dcarrb dcarrb is offline
Does "separate cooling circuitry for the block and the head" = no head gasket failure worries?
dcb
Old 09-25-2010, 11:21 AM
Manarius's Avatar
Manarius Manarius is offline
So, it looks to me like there is one big serp belt on that engine. And what the heck is the huge pulley at the bottom near the exhaust?
-Jason
-Obi Wan Kenobi
Old 09-25-2010, 12:40 PM
Looks like an idler
Old 09-25-2010, 02:02 PM
NiftySVX NiftySVX is offline
I bet it is the water pump, and the coolant changes have to do with emissions I would figure. It looks pretty standard as far as what everyone else has going on right now. I don't think it will have head gasket problems, hopefully it will be good about leaking oil, too.
1994 L Blue 3.70 VTD
ASE Master Automobile
ASE Advanced Level Specialist
Old 09-25-2010, 02:07 PM
Water pump, of course, duh !
Perfect place to turn the belt .
Old 09-25-2010, 07:19 PM
immortal_suby's Avatar
Thread Killah
One big serp on our 2010 outback 2.5 also.
externally driven water pump on a subaru? I hope the belt snapping triggers an engine shutdown.
Locker Link
2015 BRZ Limited 6MT
Old 09-26-2010, 02:32 PM
You don't want to have a water pump driven inside the timing chain cover. I think only GM is stupid enough to do something like that. It would leak coolant as it aged inside the timing cover and cause coolant in the oil. And the belt won't break if it is replaced regularly. Plus a bunch of lights would come on to let you know it did.
But I'll tell you what today's customer would notice: The a/c wouldn't work anymore.
This is a natural progression for them, and I am sure Toyota had a hand in it. I say it is natural because it really just looks like a modernized, scaled down EZ. I like that it has variable timing at each cam, and I bet the 2.5l will be good for close to 200 hp.
Old 09-26-2010, 03:26 PM
same place as on my ea81 BRAT. that engine is gear driven, no timing belt, no timing chain, so the only way to turn the waterpump is via belt. no problems, many BRATS get to the 400k mile mark on oil changes.
i like the looks of this and about time they get rid of the dreaded HG saga once again.
1985 Brat GL 138k
91 CRX Si 40k
91 CRX Si 155k
97 SVX Lsi 70k
2003 s2000
91 RT4WD 166K
Old 09-26-2010, 05:24 PM
Originally Posted by bheinen74 View Post
same place as on my ea81 BRAT...
Even the EA82's and XT6 that had timing belts, used the accessory belt to turn the water pump.
Old 09-27-2010, 07:08 PM
Thread Killah
Heh, forgot about it being a chain instead of belt. Makes sense then.
I guess it's been a while since I was under the hood of an EA82. Too many times under the svx hood has warped my memory.
Locker Link
