Old 09-20-2010, 08:33 PM
juice's Avatar
juice juice is offline
Juice
Talking spoiler
would removing the spoiler have any negative effect on performance. I'm thinking it's just for style and would only be a small weight reduction.
Old 09-20-2010, 08:46 PM
Huskymaniac's Avatar
Uses the ignore feature
Re: spoiler
Hard to say but I would be shocked if it didn't screw up the aerodynamics.
Tony
Old 09-20-2010, 08:55 PM
Manarius's Avatar
Manarius Manarius is offline
Re: spoiler
Seeing as many cars came from the factory without the spoiler, I'd say that removing it will cause little or no aerodynamic damage.
-Jason
-Obi Wan Kenobi
Old 09-20-2010, 08:58 PM
Re: spoiler
The stock spoiler has little to no effect. In any case, no spoiler is going to have much of an effect at normal highway speeds
Old 09-20-2010, 08:59 PM
kwren's Avatar
kwren kwren is offline
Re: spoiler
Get shocked! Of course it doesn't "screw up the aerodynamics". I have driven different SVX cars thousand of miles without a spoiler and after putting adding one, driving thousands of miles with it on, there is no noticeable
difference either way.
Keith
Old 09-20-2010, 09:29 PM
juice's Avatar
Juice
Talking Re: spoiler
Thats was I was thinkin.I always new guys with fwd civics adding huge spoilers were probly making their ricers slower, but just for a fun trivia question does anyone know exactly how much our spoilers weigh?
Old 09-20-2010, 10:45 PM
Re: spoiler
Maybe 10 pounds at most. It's made of fiberglass. I have one in the garage, I can get an exact weight if you really care tomorrow lol
Old 09-20-2010, 11:14 PM
kwren's Avatar
Re: spoiler
closer than twice that!
Keith
Old 09-21-2010, 04:26 AM
dcarrb dcarrb is offline
Re: spoiler
This topic has been hashed around here before, and my uneducated opinion remains the same: The SVX is aerodynamically cleaner without the factory wing, and if the wing adds any downforce at all, it's solely due to the added weight on the tail. It is not some sort of upside-down airfoil to provide "negative lift," nor is it angled with the trailing edge higher than the leading edge, a configuration which would deflect airflow upward and thus apply some downward pressure to the rear of the car, at speed.
dcb
Old 09-23-2010, 12:38 AM
Awox Awox is offline
Re: spoiler
I tend to agree. It's purely cosmetic in this cars case, and you'll likely improve your coeficient of drag by removing it.
Old 09-23-2010, 06:39 AM
Manarius's Avatar
Re: spoiler
I believe the car's .29cd was measured with the spoiler on, so I don't think removing it could make it any lower.
-Jason
-Obi Wan Kenobi
Old 09-23-2010, 06:51 AM
Re: spoiler
I'll bet it would. Anything sticking out into the airflow results in drag; if the wing does actually create any downforce, the penalty would be even more drag.
What we need here is an aerodynamicist and a wind tunnel.
dcb
Old 09-23-2010, 07:25 AM
Re: spoiler
dcb
Clearly no one knows for sure what happens. It is possible that the wing reduces turbulance. Maybe it helps, maybe it hurts. It probably doesn't make a big difference but it has to make some difference. No one knows if it is good or bad though unless they have an inside source in Subaru that worked on the project.
Tony
Old 09-23-2010, 09:43 AM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: spoiler
My vote is it increases drag slightly. On a car without one, the rear "turbulence" is mitigated by the pointy trunk lid.
Old 09-23-2010, 10:31 AM
LetItSnow's Avatar
Still Cant' Say the Z-Word
Re: spoiler
^^ This. Speculation only leads to false information.
