Old 08-31-2010, 11:50 AM
shimmersky shimmersky is offline
1997 Svx Rear Diff/driveline???????
So im getting this shuddering/vibration under acceleration always low speed and during cornering.
Feels like its coming from under the seats.
Had the driveline inspected no fault found
Had the lube fittings serviced on u joints that tomsvx hooked me up with.
Replaced the solenoid C
Still vibrating/shuddering
Removed the fuse to disable the AWD and the problem goes away???
Any known shops in California that can troubleshoot/Rebuild this system???
Thank you in advance
Old 08-31-2010, 11:56 AM
StatGSR StatGSR is offline
Send a message via AIM to StatGSR
Re: 1997 Svx Rear Diff/driveline???????
^ when you say removed the fuse, you mean added the fuse right? fuse in FWD spot = FWD, fuse out means AWD.
94 Acura Integra GSR
97 Legacy Brighton - EG33 Swap still in progress
03 Silverado 2500 - Duramax
Old 08-31-2010, 12:22 PM
correct statgsr
was trying to troubleshoot and isolate
Old 08-31-2010, 12:43 PM
Old Fogey
When you say driveshaft inspected and OK, do you include the center-bearing? Sounds very suspicious.
Glenn
Old 08-31-2010, 12:47 PM
Huskymaniac's Avatar
Uses the ignore feature
I had a similar issue with my 1997 Outback a few years ago. The center differential was binding. It is most evident when taking a hard turn into a parking space. I had my mechanic flush the ATF and replace with fresh ATF plus a bottle of Lubegard (red bottle). If you catch it early enough you won't have destroyed the clutch plates and the friction modifier in the Lubegard will get the plates working near normal again. The problem went away and hadn't returned as of 40K miles of additional driving.
Old 09-02-2010, 10:59 AM
ok so i have had 3 different shops tell me its the rear diff
any ideas on where to get one rebuilt on the west coast nor cal
plse help
Old 09-02-2010, 12:01 PM
plse help
Do you need the stock ratio, I could send you one in good condition, just the pinion gear and ring gear with lsd carrier. Shipping on it would not be very much. PM me an offer if you're interested.
Edit: also, see if anyone nearby might have one.
Old 09-02-2010, 12:36 PM
Old Fogey
Thumbs up Re: 1997 Svx Rear Diff/driveline???????
plse help
If you're anywhere near Sacramento, try Joe at Subaru Specialists. He's always treated us right.
Glenn
Old 09-02-2010, 02:16 PM
I thought the rear diff was bullet-proof. I was told that the tranny and front diff were the ones to worry about.
Old 09-02-2010, 02:17 PM
anything can wear out over time/miles. Nothing will never fail...
