Re: Mysterious Clanking Sound
Check your sway bar end links. When I bought my black one it made the same sound and it was the right front end link completely disconnected that was making the noise.
Try holding your foot lightly on the brake while it's doing it, if it stops, it's worn pins and sliders on your brake calipers. Last edited by Blacky; 08-12-2010 at 05:53 PM. |
How "solid" is the sound. If it's a very light rattling/clanking, it could even be heat shields that have started to rust away.
Checked the sway bars and the heat shields. All are good. It seems to be coming from the top of the strut; the gold-colored thing at the top of the shock... If you hit it with the dust shield, it seems to make the noise... Anything up there that could make this noise?
did you have check the bearing in the center of the main axle ? ( carrier bearing? )
i have some strange sound to, and i have find this bearing doing it. plus, the main axle move and lightly touch the heatshield below of it. so that make somes "clanks" and "tching-tching" sounds! ![]() |
I have almost the exact problem. I am going to take the front wheels off and take a good look. The noises I am hearing are coming from my left front calliper and and shock tower.
The worn pins and sliders Blacky mentioned sounds like it could be a major cause as when I depress the brakes, the sound settles down. Thanks!
1992 SVX Mica Red/Black (Ruby Pearl) (ADM)- 290,000 kms. With Koni adjustable front shocks, THRICE o/hauled 4EAT with transmission cooler and now the 'QUICK CHANGE' unit, custom PWR aluminium radiator, replacement water pump, fuel pump, crank pulley, Pioneer 6 x 9 rear and 6 inch front speakers, Sony Head unit, rattles from the front end and steering, front DBA slotted rotors. Blown heater core, ruined CV joints, new car park damage. FOR SALE... www.thebeatleboys.com |
I too have been having this problem recently. I had Subaru look at it and they were unable to determine the source of the noise with the car in the air, so it must be a worn moving part.
"That which can be asserted without evidence can be dismissed without evidence." '92 Dark Teal SVX LS-L, >146,000m 3 pedals, 5 speeds., restoration underway. 2012 Honda Insight, slow but cute. ![]() |
I'm getting a pretty solid clicking on hard left turns under power that I can feel through the gas pedal. Replaced both halfshafts. They were shot anyway.
Still there. Waiting on the ball joints to show up and those are next. But I checked my caliper and it also will wobble around like you mentioned. I'll have to take the same turn with the left foot on the brake and see what happens.
brake caliper can clank...
Keith ![]() |
![]() 1997 Ebony #308 113k "The Black Diva"SOLD ![]() 1992 Black over Liquid Silver 152k SOLD ![]() 1992 Ebony 251k 444 SOLD ![]() 1999 Silver SLK230 134k SOLD 1997 Green Outback 137k SOLD 2013 Honda Accord I4 SOLD 2015 Subaru Crosstrek 30k 2018 Tesla M3 30k |
