Old 07-16-2010, 02:16 PM
jjanak79's Avatar
jjanak79 jjanak79 is offline
subaru key
my key i got with my car is crap. has no teeth left on it and you can pull out the keys when driving. how about i do this? should i get a new ignition and have someone cut a key that matches all my locks and get a subaru key? help..
94 Subaru SVX FWD 51k
04 Mazda B4000 (work truck)
Old 07-16-2010, 02:48 PM
Re: subaru key
If it's an original key it will have a code stamped on it. The Subaru dealer can use this code to cut a new key for you.
If you don't have the key, some dealer can look it up by VIN.
They say that the key code is also stamped on the mechanism in the door, but I've never seen that.
Old 07-16-2010, 07:12 PM
Re: subaru key
If all else fails, you can get a new ignition cylinder for about $35 shipped off rockauto if I remember correctly. You can then have a locksmith change the tumblers inside the door, trunk, and glove box locks if you choose. Or use 2 keys. I currently have 2 svx that use 2 separate keys and the one that I just picked up to fix for someone local also uses 2 keys. So its not really too big of a deal.
Old 07-17-2010, 11:18 AM
Re: subaru key
It would be even less of a problem if the security fob is used.
Old 07-17-2010, 03:11 PM
Green1995SVX's Avatar
Re: subaru key
The key code is, in fact, stamped on the lock mechanism inside the passenger door.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 07-17-2010, 06:18 PM
nexus_7 nexus_7 is offline
Re: subaru key
thats good to know...as I have a Car, a Title, and NO key. now I can get a key made and start tearing this busted ass car apart.
Old 07-17-2010, 06:39 PM
Re: subaru key
You may find it easier to simply have the dealer look it up with your vin when they make you the key. If the dealership that originally sold your SVX did their job, the key code should be in the star system.
It won't cost you any more, and it's a lot easier than taking apart your door!
2009 Volvo C70 T5
2008 Volvo S80 V8
2001 Audi S8
