Old 05-29-2010, 03:33 PM
simboglide's Avatar
simboglide simboglide is offline
Oil Leak
I have an oil leak somewhere near the lower radiator neck on the engine. Anyone have photos or a link on an engine break down so i can "eyeball" how the engine / heads/ housings are assembled near there??..i have a baaaaad feeling! Seems where the 2 engine halves come together.i don't see where the lower neck is removable, seems to be cast in with the drivers side engine block.
Old 05-29-2010, 04:07 PM
simboglide's Avatar
Re: Oil Leak
http://i1013.photobucket.com/albums/...e/DSCN0073.jpg
Old 05-29-2010, 04:09 PM
simboglide's Avatar
Re: Oil Leak
it's where the black "strip" seal is.
Old 05-29-2010, 04:54 PM
Cam Cam is offline
Re: Oil Leak
It would appear that your cam seal is leaking down the front of the head and out your timing cover.
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
