Go Back   The Subaru SVX World Network > FAQs, How To's, & Vendors > How-To Docs & FAQs > Suspension
Old 05-16-2010, 01:14 PM
How-To Doc How-To Doc is offline
How-To Document Administrator
Rear Axle & Parts img
Rear Axle & Parts
01 $149.36 Housing (rear) right hand
02 $156.96 Housing (rear) left hand
03 $353.03 Rear drive shaft assembly 87ac vrh right hand w.visco-ls d 29-
... $353.03 Rear drive shaft assembly 87ac vrh right hand w.visco-ls d -19
... $353.03 Rear drive shaft assembly 87ac vrh right hand w.visco-ls d 1x-28
04 $328.89 Rear drive shaft assembly 87ac vlh left hand w.visco-ls d 1x-29
... $348.50 Rear drive shaft assembly 87ac vlh left hand w.visco-ls d 29-
... $328.89 Rear drive shaft assembly 87ac vlh left hand w.visco-ls d -19
05 $14.90 Boot (ball joint)
06 $9.64 Boot (dual oscillating joint)
07 $3.77 Boot band
08 $3.01 Boot band
09 $7.92 Circlip
10 $2.21 Snap ring
11 $5.30 Baffle plate uj
12 $6.15 Baffle plate dual oscillating joint in
13 $8.22 Boot bnd portr 87 -28
14 $1.42 Circlip lh
15 $222.89 Dual oscillating joint unit kit z=25 right hand with viscous coupling ls d
$190.32 Dual oscillating joint unit kit z=25 left hand with viscous coupling ls d
16 $182.84 Bj-shaft unit 29-
... $182.84 Bj-shaft unit -28
17 $135.10 Hub complete (rear)
18 $1.92 Hub bolt
19 $0.43 Bolt socket
20 $112.18 Tone wheel rear
21 $73.99 Bearing (rear)
22 $2.25 Snap ring
23 $6.73 Oil seal (out) -29
... $6.73 Oil seal out front 2x-
24 $8.15 Oil seal in (front) -29
... $8.15 Oil sealin front 2x-
25 $3.33 Nut (axle)
26 $0.99 O-ring
27 $2.76 Hub cap (rear)
28 $11.89 Grease 150g
... $11.89 Grease 120g
... $10.93 Grease 300g
