Old 04-26-2010, 07:01 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Rear Deck Blower
as "Ewie" was interested in the fact that my SVX had a "blower" attached - these photos I sent to Zavikan about 3 month ago to do a write-up ......
Cover
Cover with indicator showing
Indicator
Inside cover - showing copper coating - RF & EMC shielding in order that High Voltage transformer (ioniser) will not affect the antenna pickup for radio. Indicator is just below screw QC type connector & the little piece of plastic is the HV disable plunger.
Metal plates - these are the high volts parts (2Kv +) - replace lamp with LED, also notice micro switch that fits in with previous photo - disable HV when cover is off. Charcoal filter is just behind the plates & also a fan behind that.
Old 04-26-2010, 07:05 PM
SURTEESS's Avatar
Re: Rear Deck Blower
Charcoal filter being removed - cutout in the gold pasivated metalwork is to get fingers on each side of filter for easy removal.
LED indicator (added current limiting resistor) - also shows earth connector to case lid.
HV ioniser plates removed (along with charcoal filter) - showing blower fan.
HV plates & charcoal filter out of unit
HV plates & charcoal filter apart.
Old 04-26-2010, 07:20 PM
SURTEESS's Avatar
Another with HV plates & filter apart
Another - outside plates are joined (to form a shield) inner plates are also joined, these are the HV ones!!
Control switch - small fan indicator, fan is on LOW SPEED (no ioniser).
large fan indicator, only operates when dashboard fan operates this HIGH SPEED operates for approx 7 minutes before turning off ioniser automatically - but leaving high speed on.
I have replaced the indicator lamp with a green led & resistor - it only comes on when switch is not in middle (off) position.
Another shot of switch
Power is derived by t-junction from fan relay area under clovebox, remove original white connector - see next photo.
Then Connect T-junction & then place original wiring into other side of T.
Old 04-26-2010, 07:27 PM
SURTEESS's Avatar
Cool Re: Rear Deck Blower
original connector now connected to other side of T-junction connector.
The control timing module fits inside the rear window lining area - there are posts in all the SVXs that I have seen here in NZ for mounting it - I have the wiring diagram in a box somewhere......
in order to fit the rear blower, see the "how to" area about "rear speaker removal", then add remove carpet to place wiring under the plastic cover tube that sits on the floor (where the computers are). Takes about 3 hours to fit, very simple really.
The unit here was bought from a guy here in Auckland who has been wrecking 3/4 JDMs SVXs over the past couple of years (see some of my other postings for his email address - Peter is happy to post overseas) - the unit cost me NZ$100 (for everything - unit, switch, wiring, mounting screws etc).
Old 04-27-2010, 01:54 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Nice write up.
I remember there was a Japanese owner on here a few years ago asking how to fix this unit. But at the time nobody knew anything about it.
I remember talking to a guy at an SVX meet. He had one in his car but he thought it was for demisting the rear screen. He thought the dealer must have fitted it backwards, blowing into the car instead of at the screen.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 04-27-2010, 02:47 AM
Originally Posted by SURTEESS View Post
as Ewie was interested in the fact that my SVX had a "blower" attached ...
Had? What happened to it?
Old 04-29-2010, 04:01 AM
Grammar pedant.....
Old 04-29-2010, 04:15 PM
subbieatnz's Avatar
I had one fitted in my old JDM XT6. I could never get it to work.
Also other guy I knew who had a very high km white JDM SVX had the factory unit fitted. every time he turnned it on you could see sparks
I told him to turn it off and never use it.
1989 Vortex 6 Maroon
1983 RX Silver Grey
Old 04-29-2010, 04:36 PM
zavikan zavikan is offline
SURTEES:
Thank you so much for doing what I neglected to do. I have added this posting as a link to the rarities list.
James
'92 Liquid Silver SVX - Drilled&Slotted Rotors/Canadian OEM Seat Warmers/JDM Folding Mirrors/JDM Clear Corners/Euro Glass Headlights/Euro Headlight Level Adjustment/Euro Shifter Assembly/ECUTune Chip V.1/GARAGE QUEEN!
Old 04-29-2010, 05:40 PM
Mine works great! you can tell when it is on and the air seems like it has been cleaned. At least I don't have sparks when it is on. I hadn't looked to see if there was a filter or not, but now I can see what is in it.
Old 04-29-2010, 06:14 PM
SURTEESS's Avatar
Glad that so many find this article interesting, if I need to take the rear speakers out at any stage then I will remove the control unit (it has a copy of the circuit diagram, that I reverse engineered - I placed it in the box for save keeping).
Steve in NZ
Old 04-29-2010, 06:56 PM
Hi Steve - I took the pictures you posted as well as the comments and wrote up a pdf of it so it would be easier to see and read. It is here in the Interior section of the How-To Docs.
I hope this helps others.
Old 04-29-2010, 06:58 PM
Steve in NZ
If you post a copy of it, I can attach it to the pdf I did for you.
Old 04-29-2010, 07:21 PM
SURTEESS's Avatar
Ensteele,
many thanks for that - if I ever find the schematic on the computer CAD area I will forward it to the group - or if I ever need to remove the inside lining of the car, the schematic is inside the controller box below the rear LH side window.
Old 06-26-2010, 09:32 PM
SURTEESS's Avatar
Re: Rear Deck Blower - circuit diagram
Finally found it - so thought I would share...
