Old 03-25-2010, 12:18 PM
the_paynter the_paynter is offline
FS: Stage 2v7, 370cc injectors, z32maf $500
Selling the whole set up for $500 plus shipping (probably be $10-$15 shipping)
Included is
1992 ECU with the adapter and 2v7 chip installed
370cc Nismo injectors with 6000kms on them (bought new) with pig tails
Z32 MAF with pigtail
$500 + shipping!
1992 SVX: JDM STI short geared 6-speed swap, COBB short shifter, slotted cross drilled rotors, Smallcar Clear headlight lenses, 1997 Grill.
1992 RHD WRX: EJ20G, 16G, Cusco Coilovers, Wilwood 4pot/2pot brakes, Defi Genome 60mm gauges, Exotic speed downpipe, 3.5" A'PEXi spec GT catback
Old 03-26-2010, 02:11 PM
thickasxthieves thickasxthieves is offline
Send a message via AIM to thickasxthieves
Re: FS: Stage 2v7, 370cc injectors, z32maf $500
ill take it! PM sent
94 Emerald LS w/ awd 4.44 swap 199xxx daily driver
Stage 2 ECUTune chip, 370cc injectors, ECUTune valve body and TCU, solid rubber motor mounts from a forester, outlaw phenolic spacers, COBBTuning lightweight blue crank pulley, Bontragerworks 22mm rear sway bar & endlinks, StrongFlex poly front sway bar bushings, Powergrid adjustable front sway bar endlinks, 17" MOMO CORSE RPM wheels w/ Toyo Proxes4 225/45, drilled/slotted rotors f/r, stainless lines, ceramic pads, Blue silicone radiator hoses, power mode switch, gold jdm hood badge, 20% tint all around, Hella optilux xtreme yellow fog bulbs
parts waiting to go on car: the rest of the strongflex polyurethane suspension bushing set
