Old 02-08-2010, 05:07 AM
TN_fwdsvx's Avatar
TN_fwdsvx TN_fwdsvx is offline
SVX Owner
Wiper adjustment
Request for anyone with OEM wiper blades.
Please post a picture of blades in resting position. A close-up of the blade/stop relationship would really help.
I have just replaced my front wiper blades with stock and need to adjust the blades so they hit/rest on the stop properly. Did a search but no pictures or diagrams to show exactly where the blade bumper is supposed to sit on the stop. At this time they are on winter setting to keep them on the glass until I figure out where they need to be.
My thanks in advance.
Tom M
Tom Millican
'92 SVX LS-L, Claret [Daughter's]
'94 SVX LE (FWD), Barcelona Red
'99 Outback SUS, 2.5L, Winestone (Burgundy/Gray) [Daughter Killed it]
'02 Outback SUS VDC, 3.0L, Green/Gray [Spouse's; Died at 500,000+]
'18 Legacy w/eyesight, Blue [Spouse's]
'94 Subaru Sambar KS-4, White [Farm UTV]
'94 Ford Ranger Extended Cab, Tomato Red
Old 02-08-2010, 12:30 PM
Re: Wiper adjustment
Be sure the winter mode is not selected. There is a rocker switch near your hood release that allows the wipers to go fully go down in the well for winter use .
Old 02-08-2010, 01:55 PM
BoxerFanatic's Avatar
I thought that winter setting kept the blades up on the windshield glass, just above the defroster vents, to keep them thawed, and summer setting was down, out of the airstream when off...
I need to find a ny-lock nut, or something, for my driver's side... it keeps creeping down, and doesn't swipe all the way to the edge of the windshield, as the nut gets loose.
"What you plan, and what actually happens ain't exactly ever been similar..."
1992 Claret SVX. Rescued from certain destruction, and still on the road, where it belongs. Waiting for a bit of a makeover, when I can afford it.
2005 Garnet Red Pearl Legacy GT Limited 5-speed. - The late great Subaru sport touring sedan.
1999 Classic Red Miata, Preferred equipment package 5-speed. Fun, fun, fun, in the Sun, sun, sun.
Old 02-08-2010, 05:47 PM
hi if your wiper keeps loosening check the inside it may have worn out ,with oem blades set to normal postion like pervously stated ,set the blocks on the stops and tighten
charlie
Old 02-08-2010, 10:00 PM
Yes, the wipers are in the up position in the winter setting. You don't want to have it on the winter setting and then adjust them to the summer level. If you turn it off, they go too far down and could damage something.
