Old 01-28-2010, 07:56 AM
Radio light
I can't see the station # at night in my radio. Is there a bulb or a fuse or what ? If so how do I change it?
Old 01-30-2010, 03:50 PM
dennyo dennyo is offline
Re: Radio light
if it's a factory radio(oem) you're sol. only half the lights on my radio/cd/tape came on and sometimes the radio lights alone would go out completely.if i gave it a rap they would come back on.i replaced it with an 02 wrx radio now i'm a happy guy.a member here sells harnesses so they plug/play.
Old 01-30-2010, 08:23 PM
Re: Radio light
Thanks I will look into that now that I know the bulb is non replaceable
Old 01-30-2010, 08:47 PM
Re: Radio light
Any bulb can be replaced, but some have pigtails which require soldering. However this does not involve any real problem.
Old 01-31-2010, 03:53 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Re: Radio light
It's been a while since I had one apart, so I can't tell you how easy the bulb is to change.
What I can tell you is that the radio is hard to dismantle. The covers pry off easy enough, and the back piece and the faceplate. But the frame has fingers of metal that go through slots in the circuit boards and are then bent over and soldered to the board. You have to do a lot of unsoldering and cleaning in order to get the boards out of the case before you can work on them.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 01-31-2010, 05:53 AM
CorSVXette's Avatar
Classic SVX
Re: Radio light
My car seems to "eat" radios. I replaced about 4 radios so far because of the lights. I like the stock look so I look for radios for sale on this network and buy them. The price is usually good as a lot of people here replace them with aftermarket ones. Just make sure that before you buy one that the seller makes sure all the lights work. One of these days when I am feeling ambitious I will try to take 1 apart to see if I can repair the lights. I am waiting for Dave ( the radio doc) to come up with a way to "bench test" the radios to see which lights are working without having to install it in the car each time.
Paul
1969 Corvette
1995 Corolla
2003 Highlander
Old 01-31-2010, 06:26 AM
Re: Radio light
I am planning on changing mine soon because the CD player is fussy. But the light in the radio are fine. When I'm done you can have the radio for free + the cost of shipping if you want it.
Old 01-31-2010, 06:31 AM
CorSVXette's Avatar
Classic SVX
Re: Radio light
You see? This is what I am talking about. This forum is the best place to get parts for your car. The people on this forum are just great.
Paul
1969 Corvette
1995 Corolla
2003 Highlander
Old 01-31-2010, 08:00 AM
Re: Radio light
Sean thanks.... when you are ready e mail me . . Now how do u remove the radio from the dash. I have the repair manual and it does not make sense . It says remove the VENT???
Old 01-31-2010, 02:09 PM
SVXdc's Avatar
SVXdc SVXdc is offline
Radio wiring harness guru
Re: Radio light
You don't need to remove any of the vents. One of the aftermarket manufacturers say that in their instructions.
See my SVX radio installation guide.
Yes, I still need to finish that for you, but Christmas happened (and then I got sick). I'm going to measure how much current the radio draws, to see what size AC adapter would be required.
As for the bulbs, several of mine died. I was able to open up the radio enough to replace some of the ones that back-light the buttons without too much difficulty. Soldering in the new ones was the hardest part -- very fine work.
But I don't recall how much more you would need to dissassemble to replace the backlights for the LCD.
David C.
Old 01-31-2010, 08:11 PM
Re: Radio light
I printed the install removal and saved it .
