Old 01-10-2010, 02:00 PM
zaueugen's Avatar
zaueugen zaueugen is offline
heat doesnt work.. help!!
the heat doesnt turn on. and the temperature heat display doesnt turn on, neither does the climate buttons. everything is off.. which fuses control the climate control section??????
Old 01-10-2010, 02:30 PM
Re: heat doesnt work.. help!!
From the How To section above right:
http://www.subaru-svx.net/photos/files/How-To/38556.pdf
This is the under hood main fuse board.
Bottom right is a 10 A fuse, and in the same line to the left you will see a relay for the aircon compressor.
Remember though fuses don't blow for no reason, usually. Even if you replace this fuse and it's then working you should still try and find why the fuse or relay blew in the first place.
Old 01-16-2010, 04:10 PM
PearlieSVX PearlieSVX is offline
Hey man, I am having the same problem. My climate control system lights up and everything but nothing works...well the big circle button dosnt light up. and my clock stoped working at the same time.... Have you came up with anything to fix it?? I have looked everywhere for something wrong or broken but i found nothing... so let me know.
Old 01-17-2010, 11:19 PM
zaueugen's Avatar
yeah i figred it out. . its the climate control unit.. im getting another one, ask for one on the forums.
my clock works fine, so u might need something else to replace too.. ask around.
Old 01-18-2010, 12:12 AM
I've got a spare CC unit. PM me if interested
Old 01-18-2010, 09:33 AM
Wikedjuggalo's Avatar
Rebuilding
You have blown the 20AMP fuse labeled Cig/Mirror. The common short is in the sun visors wire. Don't ask me how I know. But before you replace that fuse a million times check these wires and if they are shorting up there cap them. Otherwise you run the risk of catching the car on fire. Let me know if this worked for you.
*EDIT*
you will need to unscrew the two Phillips head bolts on each sun visors. you will need to pop off the little plastic cover.
I'll provide a write up in a bit on how to fix this in detail.
Old 01-18-2010, 10:16 AM
Yea man, that kinda makes sense because my visor is broken and just hangs by the wires. Im not sure if they are ripped or anything but they might be. and ill definitely be looking for that write up.. Thanks
Old 01-18-2010, 11:04 AM
Rebuilding
Let me finish putting my pass side seat in. I'll have it written up in about an hour or so.
Old 01-18-2010, 02:40 PM
Rebuilding
as promised PearlieSVX
http://www.subaru-svx.net/forum/showthread.php?t=52869
