Old 10-03-2009, 08:06 PM
Black88GTA's Avatar
Black88GTA Black88GTA is offline
look like a leprechaun to me
Power steering issue...bad pump?
So I have a couple questions about my power steering. Signs point to the pump going bad. I think I have to replace the pump, but wanted to get some more informed opinions. I have a 1994 LSi with about 105k on it.
First - is it normal for the power steering pump to make a loud whirring / buzzing noise that is clearly audible over the normal sound of the engine running? Because mine does. The fluid is full, there is no froth or leakage, and I am not losing any fluid - yet it buzzes rather loudly. I have no other SVX nearby that I can compare mine with, so I don't know if the noise is normal or not.
I've also noticed that, during quick steering maneuvers, the power steering momentarily hits a "hard" spot - as if I have outpaced the hydraulic assist. Is this indicative of a failing pump? Or could something else cause it? Belt is tight, and doesn't seem to be slipping at all.
And finally, my car seems to resist when I make sharp left turns (like in a parking lot). Noticeably more effort is needed to make a sharp left than a sharp right. This would point more to the rack failing I think, but is there a chance that it is related? Do the racks commonly go bad in our cars?
Thanks all for any advice...
Ebony/Gray '92 LS-L, @123k - bought 01/17/2010, parked for 10 years. Getting back on the road.
Old 10-04-2009, 05:52 AM
immortal_suby's Avatar
Thread Killah
Re: Power steering issue...bad pump?
Can you take off the belt to your power steering pump and spin the pulley by hand. Let us know how it feels.
Mine died a few months ago. It made a lot of noise like you describe for a few days and then puked out a bunch of fluid when it died.
Locker Link
2015 BRZ Limited 6MT
Old 10-04-2009, 07:46 AM
hi rebuild if you are handy ,the parts are alot cheaper than a pump ,and its easy ,just dont forget the o ring on the resivoir ,the bearing is availible at parts stores ,as for the rack how are the boots ? lift up the front and turn the wheels left and right by hand and see what is binding ,inner rack joints ,ball joints are comman
charlie
Old 10-04-2009, 10:34 AM
StelthSvx's Avatar
StelthSvx StelthSvx is offline
Wink Re: Power steering issue...bad pump?
Most likely the bearing... Time for a rebuild.Only difficult part is pressing off and on bearing. I did it w huge vice and some sockets. The other gasket and o rings are pretty strait forward. I will post som pix
92' Claret LSL 282,000 miles 1owner(ME)
07' Pearly WRX 40k Cobb Stage II (sold)
SVX+$$$+GreaseMonkey =
Old 10-04-2009, 11:17 AM
StelthSvx's Avatar
Old 10-05-2009, 06:39 PM
Black88GTA's Avatar
Thanks all for the replies...sorry I haven't been on in a couple days, been a busy weekend. I had to swap the radiator in the SVX, and change the timing belt (yuck) and troubleshoot a no-start issue on my Prelude. Got all of that done, both cars are running great now, now back to the pump...
I haven't pulled the belt off yet, as I wanted the car running when I changed the radiator out to test it and check for leaks and what not. Ran out of time to inspect the pulley, as it started raining right after I got done with the rad. I may try rebuilding the pump, the job doesn't look too bad. Is there a "rebuild kit" available from Subaru that has all of that stuff in it? Or a list of part numbers floating around that includes all of the rebuild parts?
The car is down for now anyways. It was making a nasty clattering noise over bumps, so I inspected the calipers when I was down there...sure enough, the right front caliper slide pin was MISSING, and the one on the other side was backing out New pin is on order, and the car is off the road till it's in. So, if your car makes nasty noises over bumps, look at your slide pins.
EDIT: Stelth, thanks for the pics...those will be extremely helpful when I do the job.
Old 10-05-2009, 06:55 PM
If you send me your email address, I can send you a How-To with pictures.
Old 10-05-2009, 07:03 PM
Black88GTA's Avatar
Thanks Earl. You have PM
Old 10-05-2009, 07:19 PM
I just realized that I can post the How-To here for anyone who wants it. Let me know if there is anything else we need in it. I can edit if needed.
Oooooops. It is too large. It is 1.9 and the max size that can be attached is 1.0.
